BIKELAND > FORUMS > ZX-14.com > Thread: kleen air question NEW TOPIC NEW POLL POST REPLY
davisag
posted August 06, 2006 02:08 PM
kleen air question
hi
i am thinking of removing the reeds, and the kleen air from the airbox and connecting to the crankcase breather
question there is an electrical connection to a valve between the reeds on the rocker cover, so is it ok to leave this connection dis connected when the valve , etc is removed
art
jnybbad
posted August 06, 2006 05:44 PM
It is OK to unplug the KLEEN VALVE and leave it unplugged. When you put on your block off plates leave the reeds in. If you are not using plates just unplug the valve and unhook the hoses. The reeds will keep the exhaust from comming back through the system. If you want just remove all the hoses and put caps on the stock plates.
posted August 06, 2006 06:01 PM
If you want to go from the crankcase vent to the airbox, no big deal, was done lots with the 12R.
You don't want to leave the Air Switching Valve unplugged. You'll be throwing codes if you electrically disconnect it. What you could do is cap the inlet to the air switching valve and leave the hosing from it to the heads intact.
jnybbad
posted August 07, 2006 04:11 PM
Mines been unplugged for 1000 miles and no codes. Just so you know!!!
posted August 07, 2006 04:28 PM
Electrically or vacumn hose?
0.23088192939758 seconds processing time
