BIKELAND > FORUMS > ZX-14.com > Thread: Shift Light NEW TOPIC NEW POLL POST REPLY
S A Kruz
posted July 17, 2006 04:16 AM
Shift Light
What rpm are you drag racing types setting your shift light at for maximum acceleration?
Kruz
zerMATT
posted July 17, 2006 07:00 AM
I've got mine set at either 9,500 or 10,000 since HP is starting to drop off by that point anyway. BUT, since you can't really see the shift light, it doesn't matter much...
posted July 17, 2006 07:11 AM
10, 300 to keep it off the limiter!
With brocks pipe, it pulls hard right into the limiter
EASY
posted July 17, 2006 08:39 AM
I agree with Matt---I have mine set at 10.4 but can only see it if I am looking down. At 10,000 plus rpms, the road ahead seems to hold my attention a little more than down and to the right.
  Ignore this member    Click here to send EASY an AIM message.
iflyphi
posted July 17, 2006 09:49 AM
What shift light?? J/K I just watch the tach and shift at 11k. My gearing is different than stock and bike pulls hard to 11.
THEMADKAW
posted July 17, 2006 09:57 AM
set it a little past peak power. that way when you shift it it will fall right back into the power.
FasterThanStink
posted July 17, 2006 10:23 AM
Is your shift light set to bright? Man, mine is impossible to miss even on a sunny day.
That's what gets you.
zerMATT
posted July 17, 2006 11:52 AM
You must have a newer model shift light than I do... sure, I can "see" mine on a sunny day, but not while I'm doing 120+ focused on the road ahead. As Easy pointed out, the road ahead has nearly all of my attention, and that little blinking LED (bright or bright & blink) does little to get my attention!
MATTZ14
posted July 17, 2006 03:33 PM
I'm with FTS. I see mine @ whatever gear, day or night. Bright flashing. I did miss it runnin a wheelie the other day though. That sucked. I'm not real big on ridin them though and only did it cause it was already up there. Didn't hit the hi-point, limiter instead. FUC*
Later days, better lays
07 BLACK ZX14 Getting customized waiting for the white stuff to go away
06 BLACK ZX14 GONE Recall was a little late.
blitzkrieg
Road kill = Free lunch.
posted July 17, 2006 03:45 PM
Now here is an idea!
For those of you who use a H.A.R.D. system, how about duplexing the shift light into the H.A.R.D. ? That is impossible to miss.
I don't drag race, but man if I did.....
zerMATT, you have a H.A.R.D. system, what you think?
posted July 17, 2006 03:52 PM        Edited By: CrotchRocket on 17 Jul 2006 16:57
When I rode the 14 on the strip it was set for 10,500, but I shifted at 11,000...
Actually the shift light was annoying because it lit bright and took my consentration away from shifting at 11,000, I went to 11,200 during one shift but no rev limiter...
Guys if you shift at peak HorsePower then the RPM for the next gear will be below the peak HorsePower which means your losing power and that Busa will be on your ass...Always shift at redline!!!
0.22203993797302 seconds processing time
