BIKELAND > FORUMS > ZX-14.com > Thread: ZZr1400 to the alps and back NEW TOPIC NEW POLL POST REPLY
bigbob
posted July 15, 2006 12:36 PM
Just got back from a week travelling from the UK through France , Belgium, Germany, Switzerland and back through France, 2200 miles of great roads, mountain passes ( up to 2400 metres ) best roads were the susten pass in Switzerland ( Meringen to Wassen ) and N500 in Germany. Bike performed great only slight gripe was the pickup from slow bends in anything but 1st gear, 2nd too slow. It is not quick under 4k revs but great above that and ballistic above 7k revs. Some muppet complained about this in 5th or 6th, no problem as you should be using the gears ( 5th and 6th motorways and very high speed only ) but it is still a problem from low speed. Any thoughts on this, don't fancy doing the mod suggested on the valves myself.
Just ordered the Titaneum, coloured cans from Blueflame, will look great against the candy blue.
posted July 15, 2006 03:01 PM
TRE, PC3, and get it mapped on a dyno.
Almost the same as removing the throttle plates, with better idle and low end drivability.
bigbob
posted July 16, 2006 02:46 AM
Sorry not technical, I understand the Power Commander 3 and mapped on a Dyno bit but what is TRE?
droid
posted July 16, 2006 07:16 AM
Timing Retard Eliminator
Search the forum youll find lots of noise about it some loud some quiet. Dont know if its available here in Blighty u might need to get it from across the pond.
0.22620892524719 seconds processing time
