BIKELAND > FORUMS > ZX-14.com > Thread: 1/8 mile times NEW TOPIC NEW POLL POST REPLY
bishopzx12
posted July 06, 2006 01:33 PM
1/8 mile times
Hey guys i need some pointers for the strip.Went to the strip last sunday and i need to be shot for the time i ran. though i have not been on the strip in about a year i expected better out of myself. I ran constant 6.80's with about 2 7.00. My 60ft was horrific with 1.72 being my best. My bike had a muzzy pipe pcIII with muzzy map lowered in the middle hole with muzzy lowering links and about an 1.25 inches in the front. I weigh about 265. Bike only wheellied once but was not bad. I know i have 6.30's as is in the bike easily i just need to work on some form and some good shifting.. I think i am about to add the tre, a custom map, swing arm, and gas. Maybe that will get me into the 5.50-5.80 range. what you guys thinkl
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
madmike
posted July 06, 2006 02:04 PM
what rpm did you launch at? your old clutch hand is just probably a little rusty... a few more times at the track and you should be right on it...
MM
posted July 06, 2006 05:35 PM
bishopzx12 your doing good , get more seat time the numbers will drop on there own ..... Don't add any more power till you master what you have .... your bike will go 6.30s or better just the way it is ...... I started at 6.50s and so far i have it down to 6.14 with nothing but more seat time .... Smokin....
bishopzx12
posted July 08, 2006 10:52 AM
Mad mike i was launching at about 3500-4000. I have heard much more than that and you are in the air. I might try a little more nut i think you and smokin are right a little better launch and cluthc feel with a little m,ore seat time and i will be there. Smokin how much do you weigh
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted July 08, 2006 06:56 PM
Don't hate me .... I'm 150 to 155 most days ... Don't worry about your weight the zx14 was the HP to pull any weight into the nines.. Leave at 4500 , slide the clutch slowly out without a wheelie ..If the front end is still on the ground you are doing good...If it's still on the ground PIN the throttle fast and hard ... Timming is tricky but you will get the hang of it with seat time ... Smokin..
0.35481309890747 seconds processing time
