BIKELAND > FORUMS > ZX-14.com > Thread: CRG/PAZZO Lever Fitment NEW TOPIC NEW POLL POST REPLY
ZXLNT
posted June 15, 2006 01:36 AM
After having a set of Pazzo levers on my 12R I am somewhat spoiled by them. Since the ZX14 uses radial master cylinders on both the clutch and front brakes, the 12R levers wont fit. I believe the 05/06 or at least 06 636 radial front brake master cylinder is the same, so that lever should fit. Part numbers are different but I think that is due to paint color difference. Anyone know if any of the other brands use radial clutch master cylinder. I've emailed both Pazzo and CRG about levers for the ZX14 but neither has bothered to respond as of yet..
0.24992489814758 seconds processing time
