BIKELAND > FORUMS > ZX-14.com > Thread: To soften the ride,what is adjusted?.Rebound,compression or spring preload? NEW TOPIC NEW POLL POST REPLY
nabrxx
posted June 10, 2006 05:01 PM
Im taking my honey for a ride tommorrow on my new 14 and I want things to be a little more cush for her tush.Any insights are appreciated.Kawasaki is not as straight forward in their instructions as say honda was when I bought my blackbird in 98...I adjusted that bikes suspension no problem. Id like to be able to go from sport setup to a softer set up easily.Again thanks for any insights.
What we don't understand, we can
make mean anything... src="http://www.bikeland.org/board/i
mages/smilies/smile.gif" border=0>
nabrxx
posted June 10, 2006 05:54 PM
I checked some back threads and found some helpful info...disregard .
jimzx9r
posted June 10, 2006 07:43 PM
Don't soften it for 2up, you should actually be doing the reverse to handle the wifey's weight.
I hope that's what you found in your search or you'll be pogoing down the street and she'll hate you.
zerMATT
posted June 10, 2006 07:47 PM
+1 on jim there...
Simply adding the wifey's butt will soften up the ride considerably, especially in the rear. Consider this: Even if your wife only weighs 100lbs, tossing her on the back will likely add 15% overall weight to the extreme tail of the bike (depending on what you weigh). You should have pleny of "cush" already without softening things up at all.
0.25285410881042 seconds processing time
