BIKELAND > FORUMS > ZX-14.com > Thread: interesting experiment NEW TOPIC NEW POLL POST REPLY
surfinlate
posted May 30, 2006 07:19 AM
I too have experienced the weird noise on start-up that was mentioned in a previous thread. I did a little experiment to see if it had anything to do with possible bleed-down decresing pressure on the cam chain tensioner. It seemed most probbale to me, given that it only does it when the engine is cold and goes away as soon as pressure builds up. I don't yet have my centerstand which is on order (thought $180 cdn was pretty good) so I carefully propped up the bike to a near vertical position overnight and fired her up this morning. Guess what.....way less noise only heard a little portion of what I was hearing. Could be a fluke but I wonder if it bleeds down differently when it's vertical? Anyway, thought it was worth mentioning...cheers
droid
posted May 30, 2006 07:27 AM
The early GPz's had a similar problem (although mechanical cam chain tensioner) they used to have rapid cam lobe wear on the opposite side to the sidestand, through oil drain down. However now in the modern age most oils tend to leave a film in place.
What viscosity oil are you using!!
posted May 30, 2006 07:29 AM
Would be interesting to see if peeps having the prob are still on the factory oil, or it's after the first change.
surfinlate
posted May 30, 2006 07:36 AM
I'm using 10/40 dino..will change over to synth next service.....actually come to think of it , it was after my first oil change at about 800 km that I first noticed it....hmmmmm
extremelean
posted May 30, 2006 11:43 AM
There is NO prob.....The cam chain tensioner is hydraulically stabilized....the noise you hear on start up is NORMAL.....unless it does not go away.
No harm no foul. enjoy
posted May 30, 2006 12:33 PM
Aha!
0.2175509929657 seconds processing time
