BIKELAND > FORUMS > ZX-14.com > Thread: Air Induction Removal Kits NEW TOPIC NEW POLL POST REPLY
stan55
posted May 22, 2006 06:33 AM
Has any body try Air Induction Removal Kits for the Full system upgrade's. If so, how well does it work with back firing?
Stan
TJ
posted May 22, 2006 06:41 AM
Muzzys has reed chamber block-off plates.
stan55
posted May 22, 2006 07:13 AM
Thanks TJ
stan55
posted May 22, 2006 07:33 AM
TJ,
Are you going to get the Reed chaber block-off plates? If so, could you let me know how they work out with the back firing of your full system pipe?
Stan
posted May 22, 2006 08:26 AM
Are these required for all models or just Cali models or whats the scoop?
Sorry, if I seem misinformed, haven't pulled the plastic yet, waiting for pipe!
TJ
posted May 22, 2006 12:45 PM
TJ,
Stan
I am planning on getting the block-off plates. I think zxbob has block-off plates on his muzzy piped 14. I'll send him a PM.
zxbob
posted May 22, 2006 03:45 PM
TJ,
Stan
I have done the block offs ....... Muzzy sells em.
There is no additional popping - there is no additional power.
I did them only to remove the Ca. emissions and clean up misc. vacume
lines and be able to remove equipment thats not needed.
Bob
stan55
posted May 22, 2006 05:33 PM
Bob, How was the install of the block offs plates? Do you have any pic's of the install. I had a friend of mine install the block off plates on his zx-12r with Muzzy full system and it did not back fire as much as it did with the keen air. I just wondering if it did the same on the zx-14.
Stan
posted May 22, 2006 05:39 PM
Mine pops a little with the Muzzy pipe , but i can live with it ... I may get the block offs later down the road ... But really it doesn't pop that much to worry about ...
zxbob
posted May 22, 2006 06:08 PM
I took alot of pics thru all my mods, I'll look thru the pics and post up.
Their kind of a PITA to install but when done .... they clean it up a bit.
stan55
posted May 23, 2006 02:38 AM
Thanks, I'll be on the look out for the pic's.
stan
0.23383903503418 seconds processing time
