BIKELAND > FORUMS > ZX-14.com > Thread: Gear Indicator Question? NEW TOPIC NEW POLL POST REPLY
TeamSpeed
posted May 11, 2006 06:26 AM        Edited By: TeamSpeed on 11 May 2006 07:29
I am assuming the gear indicator is just a numerical calculation of speed vs rpm vs static table of stock gear ratios. I have watched my indicator, and it is incorrect quite a bit of the time. I would go from 4th to 5th at a low RPM, and the indicator will jump to 6th. Othertimes I would jump around from gear to gear, and it shows the old gear for a while until I accelerate, etc. This would indicate that the gear is just a ratio calculation, and sometimes this results in the wrong gear being shown.
If it is doing a numerical "guesstimate", then will changing the sprockets really mess up this indicator even more?
BobC
posted May 11, 2006 06:32 AM
I thought it was a resistive device, like on a Suzuki. Providing an input to the ECU rather than an ECU output derived from other data. Interesting !
Anyone know ?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
zerMATT
posted May 11, 2006 07:32 AM
I've never had mine display the incorrect gear, but it is a little slow to change the gear display when shifting. It takes a brief moment (a few milliseconds) to acknowledge a gear change most of the time.
TeamSpeed
posted May 11, 2006 07:46 AM
I will watch what RPM I am in when I go from 4th to 5th, where it then displays 6th. It is raining here for the next 4-5 days, so it will be a while before I am out again. I noticed the late updates too, but this is a different problem. Somewhere around 2K - 2.5K gear change from 4th to 5th did wierd things.
tool man
posted May 11, 2006 08:23 AM
I have not noticed any issue with my bike. Thanks with take note
The banks are failing..
The banks are failing...
Invest in Ammo
fastestbusaaround
I eat Fish...
posted May 11, 2006 09:43 AM
Me neither..slow to change sometimes...but that's probably due to data packet collisions on the CANbus, quite normal I would say. Me thinks you have a defective unit...have you added anything electrical or changed some electrical characteristics on the bike, like lights, flashers, GPS, heated grips or heated vests...anything lke that? Because if you do or did, you've got to be very careful where you take power from; it's not like the old days, where you could plug anything in anywhere...the bike runs on several computers that use data lines between to communicate. Aftermarket accessories should not be plugged into the fuse box, but rather right from the ignition switch on a seperate inline fuse...
FYYFF!!!
zx61114
posted May 11, 2006 09:53 AM
I agree with the slow to change, but dropping the clutch seems to me to be right on.
Rob
fastestbusaaround
I eat Fish...
posted May 11, 2006 09:58 AM
Oh, and I forgot that I have had an issue when pulling up to a stop...like it indicates 3rd and stays there till I pass neutral or hit 1st...this at 2-5 MPH or stopped. BFD...not a major issue to me...don't think I''ll be stalling or dropping the bike cuz of this either.
FYYFF!!!
zerMATT
posted May 11, 2006 10:14 AM
Good point. The only time I ever look at the gear indicator is when I'm cruising at slow-to-moderate speeds on the highway just to make sure I don't forget to hit 6th and save some gas. Other than that, I've got it in whatever gear feels good for the situation and I don't realy care which gear that is, as long as it gets the job done.
posted May 11, 2006 11:32 AM
Mines seem to work fine ....
TJ
posted May 11, 2006 12:58 PM
Mine works great. This is turning into a "free post" thread.
fastestbusaaround
I eat Fish...
posted May 11, 2006 01:41 PM
Actually, it's probably the only post in the last 1000 threads that hasn't been "jacked" yet...
FYYFF!!!
zerMATT
posted May 11, 2006 02:02 PM
Jinx!!
TJ
posted May 11, 2006 04:31 PM
Can anyone recommend a good cream to get rid of crabs?
TeamSpeed
posted May 11, 2006 04:35 PM
So my gear indicator has crabs, that could explain what I am seeing...
fastestbusaaround
I eat Fish...
posted May 11, 2006 04:44 PM
Its called shoveitupyerass cream.
FYYFF!!!
0.27609419822693 seconds processing time
