BIKELAND > FORUMS > ZX-14.com > Thread: counter sproket same as zx12r? NEW TOPIC NEW POLL POST REPLY
posted May 08, 2006 06:07 PM
anyone know?
zxbob
posted May 08, 2006 08:09 PM
Yes ..... its the same.
TJ
posted May 08, 2006 08:27 PM
The stock 17 tooth ZX11D countershaft sprocket was a great fit on the ZX12R. Should work with the 14 as well...
posted May 09, 2006 08:17 AM
Cool, thanks dudes!
zerMATT
posted May 09, 2006 08:58 AM
I've never changed a countershaft sprocket, is it difficult? Do you need to use a puller, or does it slide off with gentle persuasion?
tslewisz
posted May 09, 2006 09:28 AM
No puller needed. Just put the tranny in neutral, have someone stand on the rear brake (sometimes optional), and hit the nut with an impact.
TJ
posted May 09, 2006 09:51 AM
If you don't have an impact, a big cheater bar should do it...
zerMATT
posted May 09, 2006 10:49 AM
No problem with the impact... as long as I don't need to break out the 3/4 drive
Thanks guys!
0.35846209526062 seconds processing time
