BIKELAND > FORUMS > ZX-14.com > Thread: Range / Mileage / Reserve NEW TOPIC NEW POLL POST REPLY
zermatt
posted April 27, 2006 05:35 PM        Edited By: zermatt on 27 Apr 2006 20:37
For those of you that have asked, I payed a little closer attention to my fuel usage and replacement amounts when I filled up a few minutes ago. I believe this was my 4th tank.
My trip meter for this tank showed 134.4 miles traveled. The range computer was telling me that I had 43 miles left. I filled the tank to the same level as the previous fill point - probably a tad over full according to the owners manual, it took 4.267 gallons. That makes my actual mileage 31.5mpg, the computer was estimating 32.9mpg, but I am pretty sure that average included previous tanks as I hadn't reset that average since the first tank (yes, the average can be reset to start from scratch).
So, if I'm reading everything correctly, I had approximately 1.533 gallons left in the tank (I think it's a 5.8 gallon tank). Actually, I probably had more since I tend to over fill a tad, so I might be putting 5.9 or 6.0 gallons in, but we'll go with 5.8 for this discussion. Assuming 1.533 gallons left at 31.5mpg, I should have had 48.29 miles left on that tank before it was dry. The trip computer was telling me that I had 43 miles. From the sounds of this particular excercize, I don't think there is very much of a reserve past the computer's estimated range.
The thing that frustrates me a little is the fact that when your fuel level is below 40 miles or so, the huge gas pump and message "FUEL EMPTY" starts flashing, so you don't get to see your range or trip meter readings again... you have to calculate it in your head from the ODO reading. I looked in the manual, there is no way to make the FUEL EMPTY message go away without filling up the tank.
zx61114
posted April 27, 2006 07:22 PM
Matt do you have over 600 miles now? The VFR did not fully break in til about 3000 miles so my MPG went from the mid 30's to the mid 40's in that time frame. Is she still heating you up pretty good? Thanks for the updates
zermatt
posted April 27, 2006 07:36 PM        Edited By: zerMATT on 28 Apr 2006 06:29
She's got 680 miles on the clock right now (had to run out to the garage to look ). Did the first oil change Wednesday night with 609 miles showing.
I fully expect the mileage to go up with more miles too - just wanted to give some details for those who were curious.
TJ
posted April 27, 2006 07:39 PM
zermatt
posted April 27, 2006 07:51 PM
Oh, heat - It's been cooler here the last couple of days, lows in the 50's, highs in the 70's. Heat is just fine - exactly where I'd expect it to be. One segment above mid in traffic - pretty normal. We'll see what happens when the weather turns hot again next week.
havabusa12r
posted April 27, 2006 09:33 PM
On my 04R1, when the low fuel light comes on, (no fuel gauge) the dispay automatically switches to miles traveled since the light came on. It automatically resets to 0 on its own when the light comes on. On my bikes with no fuel gauge, you just get the kow light.
What does the 14 tell you? You can't switch back to MPG / range during low fuel?
(68 Yam 175 2-stroke)
(99 Copper Busa) (99 Duc 900 SS full fairing) (00 MV Agusta F4S) (02 Aprilia RSV Mille) (02 ZX 12r CTB) (03 KTM 950 Adv)
(04 Yam R1) (05 LE Busa) (07 ZX 14)
VPN
posted April 28, 2006 12:35 AM
What?!!
No way man!
zx61114
posted April 28, 2006 03:37 AM
Matt how is your chain holding up? My chain normally needs it's first adjustment right about now (600 miles). Is adjusting the chain a real PITA? One thing about the VFR I'm gonna miss is that single sided swingarm.
zerMATT
posted April 28, 2006 05:26 AM
Nope, you don't get to see anything but the clock, ODO, and a HUGE image of a gasoline pump flashing in combination with "FUEL EMPTY".
You cannot get to your trip meters or range screens... so you're *guessing* how much distance you have left, or trying to do the math from the ODO.
fastestbusaaround
I eat Fish...
posted April 28, 2006 05:27 AM
You have tried hitting the mode/reset button and the 2 together I guess? Have you tried and extended press on either one?
FYYFF!!!
posted April 28, 2006 05:28 AM
RTFM?
zerMATT
posted April 28, 2006 05:29 AM
No, I should have done that last night when I wiped the chain down and lubed it. My guess is that chain adjustement will be fairly easy - the setup looks just like my ZZR did - loosen the axle nut and the adjuster jam nuts, turn the adjuster bolts, then tighten everything back up. I'm just glad they didn't use that silly-ass accentric setup that my ZRX had... what a stupid setup that was!
fastestbusaaround
I eat Fish...
posted April 28, 2006 05:30 AM
RTFM?
I did and didn't see any mention of it either
FYYFF!!!
posted April 28, 2006 05:31 AM
Thats a good idea with the gas guage!!!...Thats Kawasaki helping those that feel the need to run on fumes all the time to just get gas and stop being a cheap bastard
I would guess when the gas pump is shown on the guage then you have approximately 1 gallon of gas left???
posted April 28, 2006 05:32 AM
Maybe it's hackable...Time will tell!
fastestbusaaround
I eat Fish...
posted April 28, 2006 05:35 AM
Crotchman...just fyi, sometimes I run on fumes cuz I was to stupid to get gas when I should have, never cuz I'm a cheap bastige...
FYYFF!!!
zerMATT
posted April 28, 2006 05:36 AM
Nope, no mention of it in the manual. I've tried hitting each button, holding them, both at the same time, holding them... everything... nothing worked.
CR - The gas pump comes up when you're at 40 miles range if I remember correctly (could be 39). I would estimate that based on my fuel mileage so far, that's somewhere in the 1.2-1.4 gallons range. I don't know if the FUEL EMPTY is directly tied to the range number, of if it goes straight off fuel level... time will tell, but so far, each time it's happened at +/- 40 miles range.
posted April 28, 2006 05:37 AM
Last time I ran out of gas on my 12, I was 20 miles down a forest road with another 10 miles back to civilization. No houses, no cell coverage...Power line crew happened by with a sat phone, was able to call in help.
zerMATT
posted April 28, 2006 05:54 AM
I generally fill up at every opportunity. The problem is that every once in a while, we'll get some joker on a RC51 or similar riding with us and he needs gas every 90-95 miles to stay safe. So, I've skipped a gas stop or two because I've only logged 60 or so miles, and I figure with 120+ mile range, I'll be fine. The problem with this sinereo on the 14 is that once I reach 80 more miles and my range is down to only 40 left, that damn gasoline pump and FUEL EMPTY start going bezerk on my gauges... it's quite distracting.
ZX11D
Internet Police
posted April 28, 2006 06:27 AM
For you metric guys, use a constant number "235" to convert MPG to liters/100 km, example, 40 mpg is 235:40 = 5.875 l/100 km
ambydupuis
posted April 28, 2006 07:19 AM
http://www.onlineconversion.com/
Does everything a man needs...
Well not everything...
zx61114
posted April 28, 2006 11:05 AM
I don't even have a bike but here is my prediction. I will Avg between 42-60 mpg if that is possible. How?
1 Weight = 155 lbs
2. Florida = Flat as a pancake
3. Elev = Sealevel
4 I'm short 5 foot 4 inches tall = I cut thru the air better..OK that was weak
5. Billy Bad Ass has a badge and there's very little going on at 5 am cept me going to work.
6. Drive like a puss until I get out of town.
Then again could going a little crazy waiting.
Rob
posted April 28, 2006 11:09 AM        Edited By: CrotchRocket on 28 Apr 2006 12:11
I hear ya Matt, thats why I said approximately 1 gallon But you cant really put a # on it because of how you ride the mileage will vary, I know you knew that though
Thats ok FBA, sometimes we forget to get gas, thats different than knowing you need gas and saying i'll make it home or I have enough to go for a ride
zerMATT
posted April 28, 2006 11:18 AM
Hell - I should say that I'm pleased that the 14 had a fuel gauge that's somewhat accurate for a change. My ZZR would stay at 100% full until there was about 1.5 gallons left, then drop like a lead balloon!
tool man
posted April 28, 2006 11:26 AM
Zermatt I too have tried to clear the silly fuel empty warning cant be done from all i tried
The banks are failing..
The banks are failing...
Invest in Ammo
0.23883318901062 seconds processing time
