BIKELAND > FORUMS > ZX-14.com > Thread: Magnetic tank bags NEW TOPIC NEW POLL POST REPLY
Tool Man
posted April 15, 2006 05:50 PM
Magnetic tank bags
Will they work on this bike? Is the tank a combination of plastic and steel? All plastic? All the fuel is down low in a "centralized" position so what is up top? I assume air box and electrics?
The banks are failing..
The banks are failing...
Invest in Ammo
Stalwart
posted April 15, 2006 05:56 PM
I guess you'll need one of them plastic magnets . . . sorry, I couldn't help it.
Stuart
Ridin' the Trump train.
Nixter
posted April 15, 2006 08:55 PM
I brought this topic up on another forum and was told that there is enough metal to hold a small tank bag, or another option was one with suction cups. I am going to hold out until I have the bike and try one out at the dealer.
2012 ZX14R - Black
VPN
posted April 15, 2006 10:21 PM
There are also those strapped tank-bra-like tank bag holders for plastic tanks
I would use one of those
Do you know how the tank looks like after using a magnetic holder after a years?
I wont even post a close-up because the chock might be so harmful
that I could get lawsuits from the most sensitive of you
Remember to use use new paint shampoo and new paint wax
buy a custom tank bra to protect her
Ozzy
need guberment cheese
posted April 16, 2006 04:15 AM
silicone some small pieces of steel under the plastic where the magnets contact.
zermatt
posted April 16, 2006 06:43 AM
I've used a mag tank bag on my ZZR on every long trip for 4 years, never had a problem. It's all about having a clean surface before you attach it to the bike. On the other hand, there may be some garbage mag bags out there that use a poor surface between the mags and the tank... smooth = bad.
My bag's a Marsee magnetic bag. I think it will still work on the 14 based on the amount of metal in front of the fuel filler.
Tool Man
posted April 16, 2006 07:29 AM
Thanks guys these are some good ideas
Invest in Ammo
havabusa12r
posted April 16, 2006 10:02 AM
On my MV Agusta and 04R1, they have the front of the tank, plastic air box cover.
Some guys do as Ozzy said, but I use the turn the tank bag backwards trick and it seems to work fine with all different bags
You'll probably have about another month? to do some research!!!
(68 Yam 175 2-stroke)
(99 Copper Busa) (99 Duc 900 SS full fairing) (00 MV Agusta F4S) (02 Aprilia RSV Mille) (02 ZX 12r CTB) (03 KTM 950 Adv)
(04 Yam R1) (05 LE Busa) (07 ZX 14)
0.22764801979065 seconds processing time
