BIKELAND > FORUMS > BIKE CHAT > Thread: Dynojet issues Fraud Alert on counterfeit jet kits NEW TOPIC NEW POLL POST REPLY
posted February 23, 2006 05:35 PM        Edited By: Editor on 23 Feb 2006 17:41
Dynojet Jet Kits are now the target of overseas counterfeiters. To the untrained eye, these kits look and feel like genuine jet kits. Users will find the results undesirable when these kits are installed.
Dynojet has already received numerous technical support calls on counterfeit kits. As these counterfeit kits are not from Dynojet, we cannot replace them. Most of these kits are labelled for 2000-2003 Harley Davidson Twin Cam 88, Dynojet part #8121.
One way to avoid being taken is to purchase your kit from a reputable dealer. While many online purchases are legitimate, make sure you find out a merchant's return policy. Beware of prices that are half of the suggested retail price, especially if the merchant has an inventory of the same kit.
Click here to download a PDF with extensive photos of the fake jet kits
Here are some of the differences between Dynojet Jet Kits and the counterfeit item:
Jet Kit Packaging Artwork
The counterfeit box sleeve uses our older flag logo, which was discontinued in 2004. The logo image itself appears flat. The background lines end around the logo instead of continuing behind as in the real package.The actual logo on the older genuine packaging had an embossed effect. The graph on the counterfeit packaging has wavy, pixelated
lines compared to the straight lines on the real product. Also on the front of the fake box, the word "Jet Kit" has lines in the background going over the text, most notably the "t" in "Jet."
Current Dynojet Jet Kit packaging uses our corporate logo and has our new postal zip code of 89081, recently changed from the 89031 previously used.
Jet Kit contents
The first thing you will notice on the counterfeit jet kits will probably be that all of the jets are in zip-lock bags. Genuine Dynojet Jets come in individually heat-sealed and labelled bags. The only way to get to a jet is to tear open the bag. A fake installation guide has an inspection number printed between the Parts List and the "Warning" text, using the number 88020304. At Dynojet, each installation guides is hand stamped upon inspection. That control number can be at any angle, anywhere on the guide. The key is to look for a randomly placed, stamped number and
not a printed number. Unfortunately, you would have to have multiple kits to notice that the stamp is in the same place as in another kit.
Performance
Dynojet Research tech support has received a few calls regarding these counterfeit jet kits. We assumed these were our product andcould not figure out why they were not performing properly. These calls were handled by replacing the "defective" parts. After the discovery and inspection of the counterfeit product, we learned that all of the jets, although stamped with different numbers, are actually the same size. This can be confirmed by using a hole gauge or jet drill to measure the size of the hole. When reading the numbers upright on each jet, the counterfeits are stamped below the hole while the real jets have the number stamped above the hole. In a random sample of these counterfeit jet kits, we have found the size of the jets to be around 172 to 178. If a consumer intends to install a 200 jet, their bike will run lean with the counterfeit parts.
Check the parts list
Although the counterfeit product lists 3 Adjusting Washers, only one is included. The E-Clip is also a shiny black material as opposed to the flat black steel of the genuine product. The fake needles were made of aluminum while Dynojet needles are titanium. In general, the material used to make the jets, needles, washers, e-clips, springs and emulsion tubes in the counterfeit product are an inferior grade and not the quality you expect from Dynojet.
Source: Dynojet Research, Inc
waltdog
EDM guy
posted February 23, 2006 09:59 PM
dynojet jet kits suck anyways...
LOL, any knock off would belike getting twice as much junk for your money.
There's a dead hobo on the patio
And an old barbed wire on the funeral fire
posted February 24, 2006 07:14 AM
dunno 'bout you, but the DJ Stage 2 kit I dropped in my Duc most certainly did not "suck" ...
Banana Bike Man
posted February 24, 2006 11:57 AM
#1 who gives a fuck about a hurley davidson peice of shit
and
B: how could you tell it was running worse? they all run like a fuck'n rototiller chopping through clay.
"Friends come in when the rest of the world moves out."
......so where IS everybody then?
  Ignore this member    Click here to visit banana bike man's homepage. Click here to send banana bike man an AIM message.
posted February 24, 2006 12:06 PM
the fraud is actually over the top.. if you check out the PDF you can see that the kits were duplicated almost exactly, and that the jets were all the same size, even though they were stamped with different #'s ...
pretty crazy when you think about the effort put into this knock off... there's gotta be an easier way to steal people's $$?
we put it up as a public interest piece as the parts turned up on ebay... even though this one case (which they caught) happened to be for a Harley, who knows what other fake DJ stuff is out there...
0.42336201667786 seconds processing time
