BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Aftermarket ECU or Fuel/Spark Remapping on ZX-10R? NEW TOPIC NEW POLL POST REPLY
KZ2ZX
Nobody in Particular
posted December 02, 2003 07:11 PM
OK - my first post here (nods to the golf-clappers).
Someone in the know - will the ZX-10R's ECU be able to be overridden/augmented by a PCIII or similar box or is the ECU itself directly programmable?
Put differently, will we be able to either add a box or directly reprogram spark and fuel maps?
If the ECU interface is different, does anyone know if Dynojet or another company is working on a Power Commander-like box for this bike?
ASMA 47
WERA 147
www.dhowellbooks.com
frEEk
posted December 02, 2003 10:34 PM
i believe DJ already has the new USB power commander listed for the 10r (someone said so in another thread in any case). it's not available yet of course, but looks like it will be. i would LOVE to see a bike with a ECU we could remap directly rather than taking the very kloogy approach of messing with the signals the ECU receives and outputs (or however it works exactly). but i doubt we'll see that anytime soon cause of legal worries or some such.
posted December 03, 2003 06:28 PM
Buy a ZX6RR and a race ecu for it...Who knows, maybe next year when Kaw gets back into Superbike racing they'll offer a RR version.
DB
posted December 03, 2003 09:10 PM
If you go to the Power Commander web site it already has detailed installation instructions and maps and prices. It says available in Jan.
Dan
04 ZX10r (Track only)
08 Concours14
KZ2ZX
posted December 04, 2003 05:32 AM
Yep.
Thanks!
ASMA 47
WERA 147
Koz
posted December 04, 2003 10:35 AM
If I am not mistaken the old Yosh box could be used on the 12. I met someone at the track (Back in 2000) that remapped an Akro. The problem is it can not adjust every 500 rpm (It adj. low/mid/high), and no timing adjustment. Also everytime you need to make an adjustment, break out the box. OH, you better keep track of previous adj., to start from stock settings.
Koz
D
posted December 04, 2003 05:42 PM
I thought the Yosh box worked on Busas/1K's?
Never heard of one bein used on a 12 - if so, I'd be interested to hear about it.
posted December 07, 2003 10:58 AM
Hoping that Kaw will have the same program as they do for the ZX6RR. You can order the entire gamet of goodies right from Ron Ayers if you have a totally ignorant dealer...
ZX600 Performance Accessories
Head Gasket (ZX-6RR Only) 11004-0004
Base Gasket (ZX-6RR Only) 11061-0036
Steering Damper Bracket, Inner Half 13280-0011
Steering Damper Bracket, Outer Half 13280-0012
Velocity Stack, 10.8mm 14073-0009
Velocity Stack, 50.8mm 14073-0010
ECU, Adjustable 21175-0009
ECU - PC/Laptop Cord 26031-0025
Main Harness Adapter 26031-0039
Fork Spring, 8.5 N/MM 44026-0022
Fork Spring, 8.75 N/MM 44026-0023
Fork Spring, 9.0 N/MM 44026-0024
Valve Spring, Intake 49078-0005
Valve Spring, Exhaust 49078-0006
Camshaft, Intake 49118-0006
Camshaft, Exhaust 49118-0007
Akrapovic Carbon Fiber Exhaust System K4243-752
Akrapovic Titanium Exhaust System K4243-753
Akrapovic Muffler Hanger K4253-419
http://www.ronayers.com/oem_accessories/kawi_performance.cfm
0.23808789253235 seconds processing time
