BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Kawasaki updates some specs - some are still TBA NEW TOPIC NEW POLL POST REPLY
DB
posted November 26, 2003 01:43 AM
SPECIFICATIONS
Engine: Four-stroke, DOHC, inline four, 16 valves
Displacement: 998cc
Starting: Electric
Bore x stroke: 76.0 x 55mm
Compression ratio: 12.7:1
Cooling: Liquid
Induction: Electronic fuel injection with four 43mm throttle bodies
Ignition: TCBI with digital advance
Transmission: Six-speed, close ratio with multi-plate wet clutch and back torque limiter
Frame: All-aluminum twin-tube backbone
Rake / trail: 24 degrees / 4.0 inches
Suspension, front: 43mm inverted cartridge fork with DLC coating, adjustable preload,compression and rebound damping
Suspension, rear: Gull-type aluminum swingarm, UNI-TRAKĀ® linkage system, fully adjustable gas-charged shock with stepless compression/rebound damping, adjustable spring preload, adjustable ride height
Wheel travel, front: TBA
Wheel travel, rear: TBA
Tire, front: 120/70ZR17
Tire, rear: 190/50ZR17
Brakes, front / rear: Dual 300mm hydraulic petal disc with radial-mounted, opposed four-piston caliper / Single 220mm hydraulic petal disc with radial-mounted caliper
Overall length / width / height: TBA
Ground clearance: TBA
Seat height: 32.5 inches
Dry weight: 375 pounds
Fuel capacity: 4.5 gallons
Wheelbase: 54.5 inches
Colors: Candy Thunder Blue, Lime Green, Pearl Blazing Orange, Black
Dan
04 ZX10r (Track only)
08 Concours14
0.29047417640686 seconds processing time
