BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Suzuki Releases 2009 Model Lineup - All New GSX-R1000 Announced! NEW TOPIC NEW POLL POST REPLY
posted September 25, 2008 06:13 AM        Edited By: fish_antlers on 25 Sep 2008 19:21
We can now confirm that Suzuki has officially released their all-new GSX-R1000 for the European market in a launch in Paris, France today. After springing a minor Internet "leak" with grainy images splashing their way across biker forums around the globe, official images are now available confirming this new model, along with European specs and colors. Also released is a new Boulevard M90, looking nearly identical to the '08 M109. Finally, there is a entry-level machine labeled Gladius (SFV-650), though few details have been released. American Suzuki has yet to unveil their lineup for 2009. Photos and specs below...
Click below the jump straight to each bike:
2009 Suzuki GSX-R1000
2009 Suzuki Boulevard M90
2009 Suzuki SFV-650
More GSXR1000 pics below
An Invitation To Own The Racetrack
All-new 2009 Suzuki GSX-R1000. With a more powerful, cleaner-running engine. A more nimble chassis and more responsive suspension. In a more compact and lighter package. Wrapped with an edgy new look. All delivering a renewed invitation for riders worldwide: Own The Racetrack.
Features
- 999cm3 4-cylinder powerplant, designed lighter and 59.6mm shorter from front to rear, delivers more power and torque, and enhanced throttle response across the entire rpm range.
- The new compact engine enabled 10mm shorter wheelbase and 33mm longer swingarm to improve racetrack performance.
- New, more over-square bore x stroke of 74.5mm x 57.3mm (changed from 73.4mm x 59.0mm) gives the engine better overall tuning potential. The compression ratio is now 12.8:1, changed from 12.5:1.
- The engine employs enlarged titanium valves in diameter, forged pistons, shot-peened conrods and Suzuki Composite Electrochemical Material (SCEM)-plated cylinders integrated into the crankcase, reducing friction and improving heat transfer, durability and ring seal.
- 12-hole fuel injectors produce a finer fuel mist for more complete combustion, reducing fuel consumption and exhaust emissions.
- Suzuki Drive Mode Selector (S-DMS) offers push-button selection of three performance settings to suit riding conditions and personal tastes. Now the switch is relocated on the left handlebar control module.
- Iridium spark plugs produce a stronger spark for better combustion.
- Large, efficient radiator with a trapezoidal shape developed on factory team racebikes and a trapezoidal engine oil cooler both help reduce drag.
- Cable-operated back-torque-limiting clutch makes for efficient clutch operation with superb feel.
- Unique Suzuki Advanced Exhaust System (SAES) uses an under-engine chamber and low-slung, large-volume MotoGP-inspired titanium mufflers.
- Twin-spar cradle frame made of five cast sections, mated with an arched swingarm made of three castings and one-piece die-cast rear subframe.
- Big Piston Frontforks (BPF) with an endurance-race-proven design deliver superb feedback and responsive, stable operation, and are lightweight.
- Rear shock absorber features adjustable rebound damping, spring preload, and both high-speed and low-speed compression damping.
- Front brakes with fully floating 310mm discs and rigid, lightweight race-proven monoblock forged radial-mount calipers.
- The edgy and clean GSX-R1000 styling incorporates fairing and bodywork details aimed at reducing turbulence and drag.
- Attention to rider comfort includes a carefully shaped seat and adjustable footpegs. Tailsection cover included for solo rides or track days.
- Sculpted fuel tank is lighter, while capacity remains 17.5 liters (4.6 US gal).
- New look multi-reflector headlight with vertically stacked high and low-beam halogen bulbs centered between position lights on each side.
- For Europe, the position lights each have layered lenses with blue coloring on the inside lens for an even sportier look.
- Front and rear turn signals feature clear lenses over amber bulbs.
- Instruments include a silver-ringed analog tachometer with LCD speedometer. LCD readouts include odometer, dual trip meters, reserve trip meter, clock, coolant temperature/oil pressure warning indicator, gear position indicator, lap timer/stopwatch, S-DMS setting indicator and bar-graph indicating the instrument lighting level, or brightness.
Specs
Engine Type: 4-stroke, 4-cylinder, liquid-cooled, DOHC
Bore x Stroke: 74.5 mm x 57.3 mm
Engine Displacement: 999 cm3 (cc)
Compression Ratio: 12.8 : 1
Carburetion: Fuel injection
Oil Capacity (overhaul): 3.6L (1.0 US gal.)
Ignition: Electronic ignition (Transistorized)
Starter System: Electric
Lubrication System: Wet sump
Transmission: 6-speed constant mesh
Primary Drive Ratio: 1.617 (76 / 47)
Final Drive Ratio: 2.471 (42 / 17)
Frame Type: Twin-spar (aluminum alloy)
Rake/Trail: 23.8 degrees / 98.3 mm (3.9 in.)
Front Suspension: Inverted telescopic, coil spring, spring preload fully adjustable, rebound and compression damping force fully adjustable
Rear Suspension: Link type, oil damped, coil spring, spring preload fully adjustable, rebound and compression damping force 2-way fully adjustable
Front Wheel: 17 M/C x MT3.50, cast aluminum-alloy
Rear Wheel: 17 M/C x MT6.00, cast aluminum-alloy
Front Brake: Radial mount, 4-piston calipers 310 mm disc, twin
Rear Brake: 1-piston caliper, 220 mm disc
Front Tire: 120/70ZR17M/C (58W), tubeless
Rear Tire: 190/50ZR17M/C (73W), tubeless
Fuel Tank: 17.5 L (4.6 US gal.)
Overall Length: 2,045 mm (80.5 in.)
Overall Width: 710 mm (28.0 in.)
Overall Height: 1,130 mm (44.5 in.)
Wheelbase: 1,405 mm (55.3 in.)
Ground Clearance: 130mm (5.1 in.)
Seat Height: 810 mm (31.9 in.)
Curb Mass: 203kg (448 lbs.)
Colors: Metallic Triton Blue & Glass Splash White, Solid Black & Metallic Mat Black No.2, Glass Splash White & Metallic Mystic Silver, Candy Dark Cherry Red & Solid Black
Photos
More Boulevard M90 pics below
Style Meets Technology And Value
The powerful, throaty rumble of a big V-Twin. The long, low, laid-back look of a performance cruiser. Combining classic styling with class-leading torque, a comfortable ride, fuel-efficiency, modern suspension and brakes, the INTRUDER M1500/SUZUKI BOULEVARD M90 looks right and feels right, delivering the best of all worlds.
Features
- 1462cm3 (90 cubic-inch) long-stroke, 4-valve-per-cylinder V-Twin engine, built to deliver massive torque while maintaining efficient operation.photo 1
- Dual spark plugs for each cylinder increase combustion and fuel efficiency.
- Hard, smooth chrome-nitride physical Vapor Deposition (PVD)-coated upper-compression and oil-control piston rings reduce friction and improve sealing.
- Suzuki Dual Throttle Valve (SDTV) digital fuel injection and engine management system powered by a 32-bit computer enhance response and efficiency.
- An automatic Idle Speed Control (ISC) system improves cold starting and stabilizes engine idle under varying conditions.
- Effective engine management system and emissions control measures allow the INTRUDER M1500/SUZUKI BOULEVARD M90 to meet latest emissions standards in respective markets.
- Cable-operated back-torque-limiting clutch with Suzuki Clutch Assist System (SCAS) makes for efficient clutch operation and a lighter pull.
- To reduce mechanical noise, each cylinder head’s cam cover is separate from the cam bearing caps, and a rubber gasket is used between the cylinder head and the cam cover.
- Dual slash-cut chromed mufflers fed from equal-length head pipes produce a dynamic, throaty V-Twin rumble.
- Inverted 43mm-outer-tube front forks deliver 130mm (5.1 inches) of wheel travel.
- A classic, rigid hardtail look is composed by hiding the coil-over 46mm rear shock absorber underneath the bodywork.
- Wide, long, well-padded seat. The comfortable passenger seat is easily replaced with an optional tailsection cover for solo rides.
- Flat-bend, drag-style chromed 25.4mm (1.0-inch)-diameter handlebars, positioned at a relatively short reach from the seat.
- Dual fully floating 290mm (15.3-inch) front disc brakes with dual-piston calipers; 275mm (10.8-inch) rear disc brake with a single dual-piston caliper.photo 2
- Wide 120/70ZR18M/C (59W) front and 200/50ZR17M/C (75W) rear Bridgestone radial tires specifically designed for the INTRUDER M1500/SUZUKI BOULEVARD M90.
- Distinctive instrument cluster, integrated into the headlight cowl under a chrome cover.
- Long, chrome-plated sidestand, designed and positioned to help make it easier to move the parked bike up off the stand.
- Multi-reflector headlight with a 60/55W halogen high/low-beam bulb.photo 3
- LED taillight with fisheye fresnel-cut smoked red lens. Bullet-shaped turn signals with unique vertical lens cuts.photo 4
- Instrumentation features a stepping-motor-driven analog speedometer and a bar-section fuel gauge always on display.photo 5
Specs
Engine Type: 4-stroke, 2-cylinder, liquid-cooled, SOHC, 54°V-Twin
Bore x Stroke: 96.0 mm x 101.0 mm
Engine Displacement: 1462 cm3 (cc)
Compression Ratio: 9.5 : 1
Oil Capacity (overhaul): 4.0L (1.6 US gal.)
Ignition: Fully transistorized
Transmission: 5-speed constant mesh
Primary Drive Ratio: 1.407 (76 / 54)
Final Drive Ratio: 2.667 (32 / 12)
Frame Type: Double cradle (steel)
Rake / Trail: 32 degrees / 129 mm (5.1 in.)
Front Suspension: Inverted telescopic, coil spring, oil damped
Rear Suspension: Link type, coil spring, oil damped
Front Wheel: 18 M/C x MT3.50, cast aluminum-alloy
Front Brakes: 2-piston calipers, 290 mm disc, twin
Rear Brake: 2-piston caliper, 275 mm disc
Front Tire: 120/70ZR18M/C (59W), tubeless
Rear Tire: 200/50ZR17M/C (75W), tubeless
Fuel Tank: 18.0 L (4.7 US gal.)
Overall Length: 2,390 mm (94.1 in.) American and Canadian spec.
Overall Width: 870 mm (34.3 in.)
Overall Height: 1,100 mm (43.3 in.)
Wheelbase: 1,690 mm (66.5 in.)
Ground Clearance: 145 mm ( 5.7 in. )
Seat Height: 716 mm (28.2 in.)
Curb Mass: 328 kg (723 lbs.)
Colors: Pearl Nebular Black, Metallic Triton Blue, Candy Sonoma Red
Photos
2009 Suzuki SFV-650
The style-focused Gladius gets an engine from the SV650 and is targeted at the more novice rider. No details are known at this point.
posted September 25, 2008 11:01 AM
Gladius <----is this copyright infringement against the Italians?
posted September 25, 2008 01:37 PM
and right after I mention this.....I see a new Bikeland post introducing the real one all redesigned for '09
ozzy
need guberment cheese
posted September 25, 2008 03:43 PM
Gixxer 1000 mufflers look like they were stolen off the batmobile
"It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses......HIT IT!"
Blues Bros.
posted September 25, 2008 06:21 PM
who uses the stock pipes anyways?
smokinzx14
posted September 25, 2008 07:18 PM
Lots of people keep the factory pipes ...
bawls
re-learning to ride
posted September 25, 2008 07:34 PM
yeah, poor people like me lmfao.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted September 26, 2008 10:15 AM
butta4hc
posted September 26, 2008 11:56 AM
As much as I am pro Kaw you can't take away from this bike. I actually bought my girl a 2005 black/gray. While it's not as fast as the 14, it feels good in every range. Those pipes need to go though!!!
Butta
Hot Commodities MC
Paterson, NJ
2006 Black ZX-14 - Recall Frame Swap, Full Muzzy GP Exhaust, PCIII, BMC Race Filter, Flies Out, Braided Front Brake &amp; Cutch Lines, Muzzy's Radiator Fan, Engine Ice Coolant, Frame Sliders, SubFrame Sliders, Puig Dark Smoke Windscreen, Powerbronze Hugger, Cox Radiator Guard, Unswitched Powerlet Outlet under seat, Switched Powerlet Outlet On Right Duct Panel, Intergrated Tail Light, HID lights high and low beam, Blue corner marker lights, Eclipse License Plate Blackout Kit, Black Pazzo Levers, Scorpio Alarm, Lojack Theft Recovery System, Rapid Transit Triple Tree Bag, Cortech Tank, Tail &amp; Saddle Bags and the bragging rights for being "The Fastest 14 In The Country" for a few weeks when the 14 made it's debut here in the states.
  Ignore this member    Click here to visit butta4hc's homepage.
ozzy
posted September 26, 2008 04:21 PM
Who stole my mufflers?
Blues Bros.
ozzy
posted September 26, 2008 04:24 PM
How right you are. Even the worlds ugliest Muzz is better looking those 'zook mufflers!
Blues Bros.
MAXIMUS
posted September 26, 2008 06:38 PM
That GSXr looks wicked, I like that.
1adam12
posted September 27, 2008 11:23 AM
Me 2 i sold all 4 of my bikes and i think next spring i will be on this biaaach! With a full yoshi damn i cant wait already having withdraws!!!
tarzan
Modulator
posted September 29, 2008 07:23 PM
Yeah, umm not sure about it.
Country music is ok if you can't hear it.
A day without a wheelie is like a day without sunshine .
Fifty Thousand
Lovin My Family.
posted September 30, 2008 04:48 AM
I read somewhere they are claiming 191 bwhp.... I dont know though
Fifty Thousand
Lovin My Family.
posted September 30, 2008 05:08 AM
P.S. how to you adjust the front end????? That shit is wild looking...
Old Guy
posted September 30, 2008 11:37 AM
Its a sad thing that Suzuki has ALWAYS built better bikes than Kawy. Sigh...., This new 1000 will probably blow the 08 zx10 and Hondas great new blackbird into the weeds......,again.
Thats ok I still love my "old" 14.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
posted September 30, 2008 06:52 PM
new blackbird, where?
TiboFew
posted October 02, 2008 02:27 AM
Track ready the 08 10 never had a chance for a GSXR.......
www.myspace.com/tibofew
  Ignore this member    Click here to visit TiboFew's homepage.
duncan
posted October 02, 2008 04:00 AM
I dissagree with you on that one.
posted October 02, 2008 06:43 AM
as usual the mags that tested threw a one liner in about suspension -
TiboFew
posted October 02, 2008 12:03 PM
How do u figure?
KZ2ZX
Nobody in Particular
posted October 02, 2008 08:02 PM
Tell me how it did, Tibo. Seriously - I need to know. Make a few minutes for me next weekend, k? BTW, you got any Cajun soup or something with flavor you wanna bring?
ASMA 47
WERA 147
www.dhowellbooks.com
TiboFew
posted October 02, 2008 10:40 PM
I don't know any cajun soup except for gumbo?
Old Guy
posted October 08, 2008 10:41 AM
I disagree also. It depends on the Nut behind the bars. One of the local track experts average placing raised due to the new 10. Its so much a better track bike than anything from Kawi before.
The Top guys are all on gixxers. I feel Suzuki didnt like how the much improved Honda and 10 reviewed against their "dated" design. I feel this redesign will blow by them a good bit, BUT we shall see.
On a XZ !!!!!
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
0.22782206535339 seconds processing time
