BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 05 zx10r neutral switch NEW TOPIC NEW POLL POST REPLY
gyminit
posted June 27, 2008 04:25 PM
I am having trouble with my neutral switch...
75% of the time it does not show neutral so can not run the bike parked with the kick stand down because of the safety switch. I just purchased the bike and not sure where to start looking for the problem
kz2zx
Nobody in Particular
posted June 27, 2008 06:41 PM        Edited By: kz2zx on 27 Jun 2008 19:48
The part you want is 13151-0005
If that shows up as a red x, you can find the part and the diagram at many online parts place (mrcycles.com, ronayers.com, bikebandit.com, etc) and enter that part number. If you look it up by 'fiche slide, it's under "Gear Change Drum/Shift Forks".
The diagram should show it's embedded in the side of the crankcase, with the shift drum butting into it (pin 92043 actuates the switch, be careful, it's got spring 92145 behind it). Its got a 92055-091 (large O-ring) sealing the oil in, this part should be removable without taking a sidecover off (two screws hold it in). I can't verify that right now on my bike.
Before you replace the part, check the connection of the cable - it routes to under the water pump outlet, looks like, by the oil heat exchanger, and check the condition of the cable as it goes back up to the LHS of the radiator into the harness connections up there.
ASMA 47
WERA 147
www.dhowellbooks.com
0.21192693710327 seconds processing time
