BIKELAND > FORUMS > ZX10R ZONE.com > Thread: axle06 on a 04 NEW TOPIC NEW POLL POST REPLY
1969ca
posted December 16, 2007 10:02 PM
axle06 on a 04
will a 06 10 axel fit o4 forks dose the nut work off of th 04 or do you need to change them both if they will fit
posted December 17, 2007 06:32 AM
if no one here has tried to swap them, maybe you could find out from your local Kawi parts man according to part numbers or such
philmy3rdleg
posted December 17, 2007 09:53 AM
No you can't. The rear you can though. I ended up buying the internal parts for the '06-'07 and bored the bearing housing of the '05 to except the parts. But you need to know about machining, bearing preload tolerance, and press fitting. It's not as easy as just boring a hole.
0.40002989768982 seconds processing time
