BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Map request NEW TOPIC NEW POLL POST REPLY
oof440
posted December 14, 2007 04:56 AM
Map request
I've got an 04 zx10r that I'm in the process of putting the thin headgasket, kawi race intake cam and degreeing the cams in. It's got a full muzzy's exhaust and bmc race filter. does anyone have a power commander map that'll get me close enough to start it on until I can get to a dyno. Thanks in advance.
mdzx10r
posted December 14, 2007 11:07 AM
I have that same set up, other than my cams are in factory holes. I could send you my map from when it was on Schnitz's dyno.
Rspec99
posted December 14, 2007 12:48 PM
I am in the process of doing the same thing. I will have a custom map done in the new year if there is not one here sooner.
Which head gasket are you running, I'm going with the .45mm
Also, I am thinking of using the factory holes on the cams too. mdzx10r, how does your bike run?
mdzx10r
posted December 14, 2007 03:10 PM
I can not remember the exact thickness, it was the thinest Kawasaki part number. The bike was definately more responsive after the change. I drag raced the bike for the past three years, and after the work I was able to better my time by almost .3 seconds, I ran a best on motor of 9.49 and weigh about 250 suited, so the bike is definately strong. I did not have it dyno tuned before the work, but on Schnitz's dyno it made 169 hp and 79 flb of torque. Another thing to note is that this map was done with the secondary butterflies removed. I also have a map for a 40 shot of nitrous it made 210 hp and 105 flb.
oof440
posted December 14, 2007 04:10 PM
Man, it'd be great if you could send me that map. My email adress is oof440@email.com. Thanks again.
mdzx10r
posted December 15, 2007 06:14 AM
sent
0.40967702865601 seconds processing time
