BIKELAND > FORUMS > ZX10R ZONE.com > Thread: gear shift light NEW TOPIC NEW POLL POST REPLY
barzinozx10
posted June 10, 2007 10:46 AM
gear shift light
How do i change when the gear shifft light comes on? i changed the gearing and i just want the bike to rev a little harder before the light comes on. Thanks.
salsa1
posted June 11, 2007 05:28 AM        Edited By: salsa1 on 11 Jun 2007 07:01
It is in the owners manual...or is it the shop manual?
for a 2004 you hold both buttons on your instrument panel down while the bike is running I believe; and then you can control the set point.. it goes up and down as you press one of the buttons....but first press both .. I think that is correct or very close.. try it...once you have the set point desired you press both again to reset back to normal...
Thats what I remember anyways...
your rpm indication has some error.. I believe 13,000 rpm is more like 12,000.. found that out at a dyno session with my 2004 ZX-10R..
Salsa1
chriscollins
posted June 13, 2007 04:55 AM
hold both buttons in untill the tach reads the shift point, then release. then use the bottom button to set the shift point up when it reaches 12500 it will start back down i think 9500 is the lowest setting then will start back up. when you have it where you want it go to the top button and set the briteness of the light, dim, medium, brite,or off. then press both buttons again to set. I always choose brite but as you are doing that hold down on the last selection of briteness then add the lower button down so both buttons are selected at once, otherwise your shift point will scroll to the next mark when you select both buttons to set.
salsa1
posted June 13, 2007 05:18 AM
Bike has to be running I believe...my instructions are like Chris so you should have no problems setting.. bright is better...
Salsa1
chriscollins
posted June 13, 2007 06:02 AM
key has to be turned on but bike doesnt need to be running
0.24234294891357 seconds processing time
