BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Stuck in 2nd gear?? NEW TOPIC NEW POLL POST REPLY
kawiguy3
posted June 08, 2007 05:55 AM
Stuck in 2nd gear??
its an 06 with 3000 miles on it. pulled away from a stop really easy shifted into 2nd fine, and then nothing. i have tried everything i can think of, the linkage and everything is fine there is still spring tension both up and down on the shifter. its like one of the pins on the shift drum broke, or the fork thing that rotates the shift drum broke or fell off?? any ideas
(BTW i dident search on this.... i hate that search thing)
heros will never be forgotton, but legends never die
Kneeburner
posted June 12, 2007 07:26 AM
Could be a bent shift fork or the shift drum. You may be able to remove the clutch basket and take a look at the transmission. If the bike is under factory coverage let them deal with it. Sounds like the bike may not have been assembled properly......
0.38123416900635 seconds processing time
