Otis
Captain Kickstand
posted June 08, 2007 03:59 AM
Help with clutch problem please.
Had a nasty highside at Mid-Ohio this week. Amungst the other significant damage to my 05' 10R, the clutch isn't working. There is no "damage" to either the cables or the clutch cover, it didn't hit there, but.. the bike fires up fine in neutral but when I pull the clutch in and drop it in 1st it automatically engages. Pulling the lever does nothing. Any ideas what could causet this? I am puling the clutch cover off tormorrow to take a look but I need help knowing what I should be looking for.
Thanks for any help you might offer.
Chris
madmike
posted June 08, 2007 09:51 AM
you probably damaged the puller shaft or the puller. so it is not pulling the clutch apart correctly...
glad you are ok!
anybody get any video???
Otis
Captain Kickstand
posted June 08, 2007 10:07 AM
I'm just really fucking sore Mike. It was a brutal crash. Thank God for Vicoden!
posted June 08, 2007 10:42 AM
sethzx10
posted June 26, 2007 08:29 PM
I have that same problem. did you find out your problem..? Mine just gradully went out very slow i adjusted the cable and it helped for day and it was gone by the end... if found any imfo on this could you please email at sethzx10@yahoo.com
Thanks,
04 ZX10R Black....
NPN
posted August 11, 2007 02:17 AM
Hi. I new with Zx10r. I have the same problem with 05. It just started few days ago and now i can't adjust it anymore. I'm going to open clutch tomorrow and check wtf there is going on. There is 15000km. Could it be clutch plates?
Thank's in advance
Toni
fattkaw
posted August 12, 2007 06:39 AM
broken pusher or destroyed pusher bearing.........
ninja_12r2000
posted August 23, 2007 04:37 PM
You got to open the clutch cover and see if the puller or the shaft in the middle are broken, or the plates got something. You maybe have to replace some parts, but it's not that bad.
wooties
posted September 05, 2007 12:40 PM
When my bike was having this problem i went to the shop and they said my clutch was kinda at a angle from an impact i guess... best bet was a new clutch in my case, i went all out and got celvar and the works.. ran me about $350 but work it in my mind. i think if you drag race alot and slip the clutch on take off the same thing results.
philmy3rdleg
posted September 05, 2007 12:56 PM
Edited By: philmy3rdleg on 5 Sep 2007 13:57
nevermind?
