BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 2006-2007 ZX10R question on FI code NEW TOPIC NEW POLL POST REPLY
33jap33
posted April 03, 2007 01:28 AM
I just purchased a 2006 Kawasaki Ninja ZX10R that had been layed over slightly. After fixing up and replacing the battery I have not been able to start it. When I turn the ignition on it powers up but the throttle body does not spray fuel out of the injectors. When I spray starter fluid directly into the intake, it runs until I stop spraying. The FI (fuel injection) Light on the gauge assembly blinks constantly which I assume to be a code for something. I was thinking that something may need to be reset... Any ideas??? Thanks, JDOG /33jap33
posted April 04, 2007 10:27 AM        Edited By: dubious on 4 Apr 2007 11:28
Tip over sensor may be stuck!
I believe it disables the fuel pump
check that cct to start!
technic
posted April 13, 2007 05:11 AM
in odometer mode hold reset button for more than 2 secs it will show the code no eg 31 vehicle down sensor
ZCNY
posted July 08, 2007 11:03 AM
did you ever find the problem b.c i have the same problem
33jap33
posted July 08, 2007 11:20 AM
The odometer gave me several codes that all lead to things on the sub-harness for the throttle body. I replaced it and it now runs properly.
33jap33
posted July 08, 2007 11:21 AM
It meaning I replaced the sub-harness on the throttle body. Thanks everyone. 33jap33
0.35105299949646 seconds processing time
