BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 2006 zx10 build up questions NEW TOPIC NEW POLL POST REPLY
mrsantafe
posted January 27, 2007 12:26 PM
I'm in the process of adding some goodies to the wifes zx10.
1. area p carbon fiber slip on
2. pc3
3. bmc filter
4. kawasaki cam
5. thin head gasket
6.-1 in front and +2 rear
I already have the first 6 mods listed
7. whatever other great suggestions you fellas might have.
What should i degree the cam at?
Any recommendations on headwork? Who, what, where, pricing etc?
How much hp with the above mods?
thanks!!
GUNNER
posted January 27, 2007 02:58 PM        Edited By: GUNNER on 27 Jan 2007 15:01
I have mine at 105/103 and it helps the middle a lot. I had them in there at 107/104 and the bike was very long winded like that. It hauled balls but was lee in the middle. When you do the cams have help and hold the pressure on the pull bar and take your readings if you release the bar and take the reading the motor will spin back up to 1/2 a degree. You'll notice this if yo take several reading at the same setting. They never match. BUT if you keep the pressure they will. My 10 was bad for this.
I will add that Coby Adams say tojust put that kawasaki cam in on the stock marks. Coby is no fool but I couldn't do that myself. AND at 105-103 you are at .040 Piston to valve on the intake. Kawasaki says you can go tighter but NOT in my book. If I had the room I would have went with something like 101 or 102 on the intake
zx10r000000
posted January 28, 2007 12:51 AM
Kawasaki racing ECU. good stuff
Y2KZX12R
CompetitionCNC.com
posted January 29, 2007 08:55 AM
Also dont forget to take into account the valve lash. It can change cam timing by a degree or more.
So for 1 mm (.040") and the lash is .008" check at .032"
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted January 30, 2007 04:34 PM        Edited By: Y2KZX12R on 30 Jan 2007 16:35
OOPS thinking of somthing else.... dont mind me. forget the above post.
Y2KZX12R
CompetitionCNC.com
posted February 16, 2007 10:27 PM
Build it all the way up to a ZX14
mrsantafe
posted February 21, 2007 04:20 PM        Edited By: mrsantafe on 21 Feb 2007 16:23
Not to worry my wifes zx10 beats my zx14. It must be the 80 lb difference. However, her bike is no match for my 12!!
0.2316210269928 seconds processing time
