BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Tick Sound From Engine 2006 ZX10 NEW TOPIC NEW POLL POST REPLY
BlackGhost
posted June 24, 2006 07:14 PM
I hear ticking noise coming from the engine upon deceleration, usually when quickly coming to a stop. Sounds like a marble in a can, or gravel hitting the fairings. Usually only 3-4 ticks then stops . Bike runs fine. Anyone have any ideas. Mods: Akro bolt ons, Power Commander, BMC air filter, removed secondary butterflies.
thundermonkey
posted June 25, 2006 08:08 AM
My 04 does the same crap ,been doing it for the last 10,000 miles either doesn't do it on the gas or I can't hear it.
  Ignore this member    Click here to visit thundermonkey's homepage. Click here to send thundermonkey an AIM message.
posted June 26, 2006 03:56 AM
Exhaust valve?
rotts4u
posted June 27, 2006 04:17 AM
My 2005 does it some now and did since new. I think its pretty common and ok.
Don
rknrl
posted June 29, 2006 10:32 AM
Ditto. My '05 does a very similar thing. Seems to be coming from the exhaust pipe. No problems so far.
GUNNER
posted June 29, 2006 11:47 AM
Welcome to the world of noise!!!!!!!!! The 10 is the worst I've ever owned, BUT like the other said it don't seem to hurt anything
BlackGhost
posted July 01, 2006 11:45 AM
Just to make sure we are talking about the same sound...I'm not talking about the valves ticking. It seems that is normal for these bikes. It almost sounds like there are little pieces of gravel inside the engine. I only hear it when braking real fast or accelerating fast. It is not loud enough to hear over the other engine noises, and it doesn't seem to be RPM related. It sounds like gravel hitting the fairings, and it happens all the time. The bike rides fine though. Just concerned.
k bryant
Sponsor
posted July 01, 2006 01:05 PM        Edited By: k bryant on 1 Jul 2006 14:05
If you removed the the pulley from the servo motor located under the seat when you did your mods, it's possible the gears from the servo shaft got out of sync/time. When they do, they kinda "hunt" or rachet. I've seen several do this. It does not seem to affect anything when the cables are detached, but it can be annoying. If it was this, it would make that same noise when you turn the ignition on and it cycles (the engine does not have to be running). Just a thought.
BlackGhost
posted July 01, 2006 02:43 PM
I didnt do the exhaust butterfly mod yet. Just the secondary throttle body butterfly mod. The sound comes from the tank area.
redline659
posted June 14, 2007 11:24 AM
HAHHAHAHA, you want to hear noise remove the rubber trash bag they put over the top of the motor to keep the noise down...........
0.23321199417114 seconds processing time
