BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Headlight scratch removal ? NEW TOPIC NEW POLL POST REPLY
lastman
posted April 24, 2006 04:24 AM        Edited By: lastman on 24 Apr 2006 07:39
Has anyone tried any of the following products to remove marks/scratches from their headlight unit?
Products seen are -
Meguiars #17 plastic polish
Meguiars #10 plastic cleaner
Novus plastic polish
Anyone have experience of using any of the above
posted April 24, 2006 07:17 AM
Novus 3 is the heaviest scratch remover... I'd start Novus 2 ... we use Novus at work all the time.
novus is easy, use 3, then 2, then 1.... or 2, then 1 (generally) very rare you find a scratch that needs 3. I used it to polis out a scratch in my instrument cluster on my 12R once... worked like a charm
TedG
posted April 24, 2006 07:35 AM
It all depends on how deep the scratches are. Deep scratches need to be wet sanded out first with 2500 grit wet or dry. Then polished out. Start with rubbing compound, that will bring it back to clear, then fine polishing compound. Then use the Meguiars #10 and finally #17. The best results will be achieved using a power buffer with a foam pad. You can get excellent results by hand but it takes elbow grease.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
0.291179895401 seconds processing time
