BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Fan Issues...HELP! NEW TOPIC NEW POLL POST REPLY
Liverpool-Mad
posted August 25, 2005 08:41 AM
Fan Issues...HELP!
Trapped in traffic getting to the twisties, noticed my legs cooking...and my fan was not turned on. Checked the fuse, it was fine. Wired the fan to my horn just so I could get home (so the fan motor is not the issue).
Odometer was registering 240 degrees plus...so I figured the water temp sensor was ok. I borrowed a relay box from a friend and fan still won't turn on...so it's not the fan relay.
Anybody else run into this problem? I'm thinking it's still probably the temp sensor not sending a signal to the ECU properly?
Nothing worse than electrical crap...
Hells Dark Lord
living life, and loving it.
posted August 25, 2005 05:03 PM
no idea...good luck and let us know what you find out
frEEk
posted August 25, 2005 05:44 PM
u made sure the system is full of coolant? on some bikes not having the rad full can cause that problem.
TedG
posted August 25, 2005 07:34 PM
Usually there are two sensors for the coolant. one for the guage and one for the fan.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
Liverpool-Mad
posted August 26, 2005 10:08 AM
Coolant level was fine.
There's one coolant sensor...but it's wired into 2 circuits. It has 3 leads coming out of it...2 for the fan circuit and 1 for the gauge (according to the wiring schematic).
I guess it's possible that the gauge lead is fine but the other 2 are not working right.
Will let you know...thanks.
0.20804405212402 seconds processing time
