BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Custom Power Commander map or not? NEW TOPIC NEW POLL POST REPLY
timsterc
posted August 24, 2005 01:30 AM
Hi Folks,
So almost finished the break-in (the weather is sh!t in UK most of the time), and I'm wondering whether I should ask Santa for the funds to get a custom PC map made up.
I've got;
2005 ZX-10R (green)
Akrapovic slip on, without the baffle in
Power Commander III USB
Euro 10R, Akropovic, map from the DynoJet website.
When I'm running up to to a stop line (coasting + off the gas), I get a lot of popping and banging.
Is this normal? I also get enough to cause a backfire.
Don't get me wrong, I kinda like it, but I'm not sure it's the best way of endearing myself to the neighbours.
Any thoughts on whether it's worth the £175 it's going to cost to get a custom map made up, or is the map from the PC website good enough?
(Might not reply too quick as I'm away on the bike for a holiday weekend, back Tuesday)
Shiney side up,
Sticky side down.
;o)
  Ignore this member    Click here to send TimsterC an ICQ message. Click here to add 89556129 to your ICQ list. Click here to visit TimsterC's homepage. Click here to send TimsterC an AIM message.
justoyz2
Justoyz Racing
posted August 24, 2005 02:52 AM
-the cause is a lean condition
-I don't have a problem with the popping, becasue the bike respond better when you come back on the gas (my opinion)
-I am sure there are some that will disagree, but it's your choice to richen the map in your 0 and 2% throttle position. This should take care of the backfiring.
-some will tell you by your fresh air system, but I have mine on my 05 zx10
-you can remove it and still have the back firing, if you run the mix lean
0.20818305015564 seconds processing time
