BIKELAND > FORUMS > ZX10R ZONE.com > Thread: KAWASAKI DERESTRICTOR NEW TOPIC NEW POLL POST REPLY
04ZX10R
posted February 10, 2005 11:50 AM
was reading a thread and someone mentioned danosperformance.com went there and saw the derestrictor. has anyone bought and tried it . any feedback would be appreciated. thanks in advance mario
beansbaxter
posted February 10, 2005 01:05 PM
hmmm i dunno....looks like you can make it for less than a buck.
posted February 10, 2005 04:22 PM
hmmmm.... never thought the 10 needed "derestricting"... are we sure about this product??
12RPilot
posted February 11, 2005 08:00 AM
Looks like a TRE to me. Our bikes aren't restricted.
NESBA #209
o
posted February 13, 2005 08:34 AM
Does anyone know and can prove the truth on this? Its only a $32 part. From Dano's site-----------> "Kawasaki's ZX10R model has electronic circuitry which retards the ignition timing in the first four gears, which also reduces the horsepower. Simply plugging in our Derestrictor unit will dramatically increase power in the first four gears and will improve throttle response. For this reason this is a must have performance upgrade. Installation time for this unit is about 30 minutes. Also included is a set of detailed instructions and the special tools that are required to install this unit. The Kawasaki Derestrictor (KDR) unit will fit 2004-05 Kawasaki ZX10R models."
PBO ZX10R
frEEk
posted February 13, 2005 10:22 AM
well that's not the common interpretation of the term "restrictor", which is usually applied to peak HP. frankly unless u have an extended swingarm having more power in gears 1 thru 4 aint gonna do you any good anyway as ur having a hard time keepin teh front end down as is (which i'm sure would be the point of such a restriction to begin with). jsut don't think u'r gonna get higher readings when you go to a dyno after installing that thing.
o
posted February 13, 2005 08:10 PM
just change the sprockets?
PBO ZX10R
0.28732395172119 seconds processing time
