BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Help F.I light is flashing NEW TOPIC NEW POLL POST REPLY
guzmanx-zx10r
2005 zx10r
posted December 10, 2004 10:26 AM
Help FI light is flashing i was loosing power during shifting and reving, does anyone know what might be the problem here i dont see why i would have a problem with my fuel injection..thanks
I refuse to tiptoe through life only to arrive safley at death
  Ignore this member    Click here to send guzmanx-ZX10R an AIM message.
bluedevil
posted December 10, 2004 12:22 PM
Are you using a PCIII?
guzmanx-zx10r
2005 zx10r
posted December 10, 2004 12:49 PM
no all stock still
bluedevil
posted December 10, 2004 03:20 PM
Start with basic troubleshooting 101(visual inspection)first. Check the ECU connectors and the FI connector under the airbox and just an all around check of loose, binding frayed wires/connectors. While you are doing that you can check for other connections/hookups as well. Just a good place to start. If this is an intermitant problem than it could be much harder to locate the culprit if connections are good.
Bluedevil
trikchop
posted December 10, 2004 03:48 PM
no help for you bad ebayer. rot in hell.
kz2zx
Nobody in Particular
posted December 10, 2004 03:58 PM
Guzman, is your bike Euro-spec or US-spec?
It shouldn't be flashing until you put it in Dealer Mode if it's US-spec.
Anyway, count the flashes - 6 flashes a short space, then 3 flashes would be 63. So what's the code?
ASMA 47
WERA 147
www.dhowellbooks.com
kz2zx
posted December 10, 2004 03:59 PM
trik, wtf?
ASMA 47
WERA 147
trikchop
posted December 10, 2004 04:04 PM
my friend purchased a plastic from this guy on ebay, but he changed his mind AFTER the auction ended and the money order was in the mail.
kz2zx
posted December 10, 2004 04:09 PM
Ah.
Is a stalking enough revenge? Did your buddy get his MO back?
ASMA 47
WERA 147
trikchop
posted December 10, 2004 04:33 PM
no. and its been a month. it isnt stalking either i come to this site every day.
DB
posted December 11, 2004 01:15 AM
Have it looked at my a dealer under warranty!
Dan
04 ZX10r (Track only)
08 Concours14
guzmanx-zx10r
2005 zx10r
posted December 11, 2004 04:20 AM
i sent the money back a while ago and i wasnt going to let the part go for a dollar thats isane
guzmanx-zx10r
2005 zx10r
posted December 11, 2004 04:28 AM
and if i wanted to be a thief i would of cash THE MONEY ORDER but did i NO SO DOES NOT MAKE ME A THIEF....SO DONT COME HERE AND HARASS ME....
trikchop
posted December 11, 2004 06:31 AM
well summummabitch thats why you put a reserve or raise the starting price up to where your comfortable.
guzmanx-zx10r
2005 zx10r
posted December 11, 2004 12:15 PM
fine i will do that next time i dont want any bad feelings from anyone iam not here to start any trouble
10rmotor
posted December 12, 2004 11:03 AM
When I power up the ECU (motor is in a race car), the light stays on and doesn't flash. I'd assume it would flash codes for the missing exhaust valve actuator. Do you just ground the diagnostic wire for more than 2 seconds to make it dump the codes, and should the wire stay grounded? I've followed the directions in the manual and the LED just stays on.
0.28216290473938 seconds processing time
