BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Akrapovic s/steel full race system ????? NEW TOPIC NEW POLL POST REPLY
wwwrxxx
posted November 22, 2004 12:19 AM
Has anyone installed one of these with a titanium can and compared the results to stock?
FP 10R
Fast Learner
posted November 22, 2004 05:33 PM
I have fitted a full Ti race system and can and the results are significant over the stock system as would be expected.
As for the SS system I don't know but I would assume the gain to be simular Akra make many varied systems and it depends on what one you buy, a full race system would not be available for road use as the noise level is prohibitive.
"Life is not a rehearsal so make the most of it" Carefully
  Ignore this member    Click here to visit FP 10R's homepage. Click here to send FP 10R an AIM message.
wwwrxxx
posted November 22, 2004 05:47 PM
Ahh yes, louder but no more illegal than the way I ride the bike.
That's good to hear. The s/steel system is identical in size and shape to the ti product, only slightly heavier, so HP improvements should also be identical.
I have also been told the ZX10R remaps itself automatically. That there is a wideband sensor in the head on the exhaust side that feeds back info to the ECU, therefore, no need to remap for the pipe.
Anyone know if this is true or not?
Cheers
FP 10R
Fast Learner
posted November 22, 2004 06:14 PM
Not on this Planet!
den
posted November 22, 2004 07:07 PM
you're dreaming!!!!!!!!
fattkaw
posted November 22, 2004 08:34 PM
there's also a pool pass under the passenger seat!
12RPilot
posted November 23, 2004 08:12 AM
That's about all that will fit under there!!
NESBA #209
wwwrxxx
posted November 23, 2004 08:22 PM
The system is on and on the road the bike feels awesome at the top with a ton of mid range. I never use below 4K to know how different it is down there.
I emailed Akrapovic and they insist that the system is designed to go on a stock bike, no mods.
The only tuning thing I have noticed is it seems that on the overrun I get the occasional pop from the exhaust.
It now power wheelies 3rd gear. Roll it on from 4K and hang on.
fattkaw
posted November 23, 2004 09:34 PM
put the block off plates in if the pop bothers you.
Ivan sells them for $35
wwwrxxx
posted November 24, 2004 11:03 PM
Hi,
What are the block off plates?
Regards
fattkaw
posted November 25, 2004 05:23 PM
http://www.ivansperformanceproducts.com/other.htm
wwwrxxx
posted November 26, 2004 02:49 AM
I'll be testing the performance gain on the road this weekend.
My friend has a K4 Gixxer 1000 with a Micron Serpent, remap, k&n filer and 16t front spoocket.
I ran him with only a 16t sprocket on my 10 and he marginally pulled away.
We both weigh 82kg and are both running 98RON unleaded.
Now I've got the 16t sprocket and the race Akrapovic.
Happy to post the results if anyone is interested.
wwwrxxx
posted November 27, 2004 09:53 PM        Edited By: wwwrxxx on 27 Nov 2004 23:21
the news is the pipe works well. We are now dead even. I can get away a fair bit quicker and stay in front due to the tall 1st gear. If we roll on from about 140kph, we are a dead heat till both bikes are reading 299.
His bike has been on the dyno and came up with 164HP at the back tyre.
0.2120418548584 seconds processing time
