BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Clutch cable routing NEW TOPIC NEW POLL POST REPLY
wwwrxxx
posted September 11, 2004 02:28 AM
I slightly lowered my levers and found my clutch cable being jagged between the front brake line and throttle cables.
If you turn the steering full lock left all the slack in the clutch lever was taken up.
I re routed it so it goes over the brake line instead of under it and it is heaps better.
Every 10 I have seen in Australia has the clutch cable going under the front brake line.
Is it the same with the US models?
Hells Dark Lord
living life, and loving it.
posted September 11, 2004 04:42 AM
if i could get mine out from in front of the gauges I would be happy, no matter who I route it its still goes in front of atleast part of them...
big daddy
posted September 11, 2004 07:37 AM
yes the cable works best routed outside the brake lines.
BD
0.21660304069519 seconds processing time
