BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Hyperpro RSC steering damper question NEW TOPIC NEW POLL POST REPLY
greenzx
posted September 10, 2004 11:49 AM
Got it installed, the problem I have is now I can't turn the clip-ons to full right lock...the damper cylinder bumps the mount on that side.
I used both the metal washers but it still doesn't clear.
Anybody else have this problem?
Drew
D
posted September 10, 2004 12:07 PM
Adjust the damper body in the center clamp until ya have clearance.
greenzx
posted September 10, 2004 12:24 PM
Ok, you mean sliding the damper body in the center clamp until it clears, eh.
Sorry if this sounded like a dumb question, but I've only installed rotary dampers, so this is my first cylinder type.
I'll give that I shot this evening.
Thanks D.
1bad7
posted September 10, 2004 12:27 PM
Yeah, you'll have to adjust the body of it, then you should have no problems. I love mine.
Yannick
posted September 10, 2004 12:42 PM
I don't have it here with me but the mounting instructions that came with the damper indicate the proper placement to avoid clearance issues.
otto65
posted September 10, 2004 03:28 PM
Yannick is correct . there is a measurement in the instruction on where to set the damper in the clamp.
Its all part of my master plan to rule these worlds
Ground Zero
posted September 10, 2004 07:17 PM
Damn. That instruction thing again....
It's an awsome dampner. You will love it.
wwwrxxx
posted September 11, 2004 02:23 AM
I'd love to see a pic of it. wwwrxxx@westnet.com.au
I've got the same damper from muzzy. Maybe the mounts are different. I don't have any issue with the side to side clearance. Mine might be higher geared if the brackets are different.
I'll email a pic of mine to compare... (need your email address)
Ground Zero
posted September 11, 2004 04:18 AM
Here is a pick of the installed dampner:
iculukn
posted September 11, 2004 05:06 AM
$400 plus " OuCh". Where can a broke man buy a damper ... cheaper than what I see everywhere I look. Purhaps I just need to close my eye's.
On another note though, don't you just love the way your 10R starts bringing the front up under power 1st thru 4th.
It's like hanging onto the wife while saying her sister is much tighter, hard to do but what a Rush,
-lukn
A "99.99% open mind", is still closed!
wwwrxxx
Have yeself a geezer aye
http://au.pg.photos.yahoo.com/ph/wwwrxxx/album?.dir=52ca&.src=ph&store=&prodid=&.done=http%3a//au.pg.photos.yahoo.com/ph/wwwrxxx/my_photos
the muzzy brackets are a little more subtle.
iculukn
posted September 11, 2004 05:07 AM
wwwrxxx - you guys are killing me with these pixs
-lukn
Evander
posted September 11, 2004 07:25 AM
Does anybody know if the RSC can be mounted on the bottom of the triple clamp to the underside of the frame? I've seen a ZX-10R with and Ohlins mounted like that and wonder if it can be done with the Hyperpro?
Ground Zero
posted September 11, 2004 07:31 AM
Haven't seen any mounted below, but I guess anything is possible.It's nice though to have it up top to adjust it for different riding condidtions.
kevy10
posted September 16, 2004 04:32 PM
first through fourth?? my 10 will deffinately not raise the front end in fourth. with out slipping the clutch that is.
posted September 20, 2004 01:33 AM
I've found that the bike is very sensitive to where your weight is. Keep up against the tank and all is well. Bike will pull hard out of the corners and not shake it's head. Let your butt slide back, tho, and the front end will definately get light and wag back and forth, if not come up in third and forth.
kevy10
posted September 20, 2004 03:39 PM
I do agree with that swft, and that is exactly how i ride. Ikeep my self tight against the tank. I found the bike responds very well to my body input this way.
0.26806092262268 seconds processing time
