bullet
posted August 25, 2004 05:29 AM
resonating at 4000rpm
Hi guys,
I dont know if somebody has already figured and posted this, but I just discovered that the resonating sound which can be heard somewhere 4000rpms is coming from the tacho/speedo assembly.
cheers
posted August 25, 2004 05:32 AM
Yah, there was a guy that mentioned a couple bolts up there that typically work themselves loose.
ninja_12r2000
posted August 25, 2004 05:34 AM
Rattle
Well on mine it's coming from the left side of the fairing.
Resonating from the fairing I guess.
But because I install a double bubble fairing some of the sound amplified comming from the front soo.
I just ignore it and I feel fine.
posted August 25, 2004 05:37 AM
The only noise I have is gear whine, and that goes away when I go over 75.
bullet
posted August 25, 2004 05:40 AM
woah, you guys replied quickly.
salsa1
posted August 25, 2004 05:52 AM
check horn under tach/speedo assembly if it's loud. whatever loud is....
I fixed a high frequency metal to metal noise that I traced to horn leaning against metal. Possibly my ZX-10R was only one with this problem but I doubt that. Just re-informing just in case.
Have fun;ZX-10R is louder than average ;too many light weight parts and construction I suppose.
Salsa1
