rubber pants
posted August 17, 2004 08:53 PM
Rattily Humping!
Just wondering if any of you people noticed that the fit of the seat hump cover is rattily as hell!
When I ride this thing I think all the buzzy rattles are coming from there! So I siliconed around the seal area and when it drys we will see what goes!?? I find it's like a bit of an afterthought and cheap!! Which really suprizes me for a Kaw!
Is mine the only cheap rattily one?!???
"Ya Gotta Have Big Ones!"
speeddemons.com
posted August 17, 2004 09:27 PM
You just did'nt adust the rear bracket when you put it together...
sp500
posted August 17, 2004 10:34 PM
they all rattle unfortunately, some people have put tape around the bar where the cowl slots into.
04 ZX10R
salsa1
posted August 18, 2004 04:42 AM
One thing causing annoyance to my ZX-10R:
The horn which is located under ram air column was rattling like crazy as it's outer rim was laying against metal and when riding ;would annoy big time. Finnally located it as the source of vibrating noice and bent it back away from metal; problem solved.
Hope this helps if you have this problem.;my desrcription is a bit vauge but you should be able to understand once you locate horn and see how it sits.
Have fun;stay alive.
Salsa1
12RPilot
posted August 18, 2004 05:21 AM
Hmmm....I have an annoying buzz from somewhere behind the gauges. I gotta check this horn thing out.
NESBA #209
posted August 18, 2004 06:12 AM
I've got this buzz between my eyes...Oh wait, that's the caffeine.
salsa1
posted August 18, 2004 06:16 AM
It's a metal to metal hummm. You will be happier once you bend horn outer rim away from touching anything.
Noise would come and go depending on engine speed. Came from the dealer that way. Wonder if dealer assembles that part of bike; but ...whatever got it fixed now.
Salsa1
reilly809
posted August 18, 2004 01:24 PM
Rubber Pants
Try puting a thin washer under rear bracket, and two thin rubber washers under the two front stock rubber ones that came with the cowl. (where they latch in the front) . Makes a big improvement on fit , you will have to push a little harder to latch the cowl but its worth it for a good fit!!
Hells Dark Lord
living life, and loving it.
posted August 19, 2004 05:51 AM
i am getting a buzz with my bike too....but mine is coming form the right upper fairing, its rattleing against something....I can hear but cant find it....
posted August 19, 2004 07:00 AM
Check your clutch cable.
rubber pants
posted August 19, 2004 08:13 AM
Thanks reilly809! I did that too.... I managed to put a bead of silcone around the area that was rubbing and after it dried it's way better!!!
speeddemons.com
posted August 19, 2004 08:40 AM
Edited By: fish_antlers on 19 Aug 2004 09:59
I guess people here dont bother to search to see if this has been discussed before.. .if you had then you would've seen my post many months ago about this problem and how to fix it ....... here.......
http://www.bikeland.org/board/viewthread.php?FID=19&TID=11550
rubber pants
posted August 19, 2004 09:54 AM
Ya but fish... you were saying back then that "it wasn't rubbing" mine wasn't either till after all this time and I actually had some white powerdery proof of it, and that thing was buzzing back there. I tried all those things you people were suggesting to no avail. The bead of silicone I put under the cowl on either side of the front of it cured it totally. So... thanks it's all good.
I do find though that alot of buzzing from other places, happens too! I guess it's just that the thing is made so light that the faring etc is just loosening or?? Maybe I better wear ear plugs more often!
speeddemons.com
posted August 19, 2004 10:14 AM
i c ..... the bike is definetly noisey... but hey.. it's not a goldwing.. it's a racebike.
ninjatech
posted August 20, 2004 01:52 PM
I prep these bikes for UK magazines and have found that on every one of our press fleet, the two top headlamp bolts work loose from the meter bracket and need to be secured with locktite or similar thread lock otherwise they may resonate through the top cowling, the cowling stops them falling out completely. As for the seat hump make sure that the two rubber dampers are in place otherwise they do rattle.
posted August 24, 2004 07:34 AM
bump
Hells Dark Lord
posted August 24, 2004 06:38 PM
quote: bump
bump again....
posted August 24, 2004 06:43 PM
bump to infinity and beyond!
Hells Dark Lord
posted August 24, 2004 06:44 PM
hehehehe, he said bump.......
posted August 24, 2004 09:10 PM
Does it rattle over bumps?
Hells Dark Lord
posted August 25, 2004 01:47 AM
does what rattle of bumps, the humps?
salsa1
posted August 25, 2004 04:45 AM
Edited By: salsa1 on 25 Aug 2004 05:46
should we bump rattling humps or hump rattling bumps;
I'm confused...
Salsa1
posted August 25, 2004 05:30 AM
Maybe someone bumped into humping rats!
Hells Dark Lord
posted August 25, 2004 03:39 PM
ewww @ humping bumpy rats......lol
