HPower
posted June 22, 2004 09:22 PM
Torque spec 4 steering stem nut?
I am sure this has already been asked, but...
I just installed an Ohlins steering damper and need to torque down the steering stem nut.
What is the correct torque spec and what size socket, 36mm?
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted June 22, 2004 09:29 PM
58 ft lbs
CanyonCarver
posted June 23, 2004 05:26 AM
58 ft lbs is correct, and it uses a whopping 36mm socket. I actually found one of them hanging on the rack at Sears. Pleasant surprise.
posted June 23, 2004 05:33 AM
I got lucky and had one in my impact set. And there was enough room to use it.
posted June 23, 2004 06:20 AM
I had to buy one .. hard to find but very usefull to have around!
HPower
posted June 23, 2004 07:42 AM
36mm and 58ft lbs it is.
Thanks for the help.
