600rr
posted June 13, 2004 10:01 AM
Front Sprocket Nut is Weird
well i just pulled the cover off and im at a loss for words.....how the hell do i get this thing off.....a 27MM nut is to lose.....maybe becase the nut is allready rounded off from the factory......any suggestions people?....please help my newbie ass
salsa1
posted June 14, 2004 04:58 AM
Edited By: salsa1 on 14 Jun 2004 06:02
I had to take mine to a local mechanic and he used an impact air compressor tool to loosen up for me.I took over from there. He tightened enough for me to get home and take off ;(I supplied deep socket $5.85 at local advance auto parts).
Tough to loosen just by yourself with regular tools at home I thought ..
Could have an accident in the process,not worth it.
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted June 14, 2004 07:47 AM
Use the inner nut exposed by hammering the lockring flat. You can loosen it with a long socket wrench if you put the front wheel against the wall. It really helps to have a partner sit on the bike, especially to mash the rear brake for re-installation. Or buy a compressor, some air tools, a Handy lift, a ratcheting tie down (for the brake pedal) and be done in 5 minutes. Being a tool whore has its advantages.
posted June 14, 2004 07:55 AM
If you can use an air impact, just put the bike in neutral, hold the back tire with your hand or the brake, and pull the trigger.
Doug
salsa1
posted June 14, 2004 08:20 AM
Edited By: salsa1 on 14 Jun 2004 09:27
I paid just $5.00 to mechanic to loosen for me; I have no partner to help me do it at home or would try by myself (poor me hehe).... I would make sure you are loosening by inner nut after flatening lockring washer to be right.
good luck;
PS;I will dish out another $5.00 and go from 16 front to 15 tooth this week.; checking account is still happy.
I took off sprocket cover myself ;took mechanic 2-4 minutes then I put cover back on at home when done.....
600rr
posted June 14, 2004 09:37 AM
ok guys you make it sound so simple......but your leaveing out all the usefull information like.......socket size.....i know the second part of the nut is 27mm...but what is the inner size
salsa1
posted June 14, 2004 10:10 AM
Edited By: salsa1 on 14 Jun 2004 11:15
I have the socket size at home. I took ZX-10R with cover off to auto parts store and tried a couple of sockets to find out (you could too). I will check and tell you tommorow if no one posts before then....if doing by yourself and do not have impact wrench not so simple to do...
best I can do for ya for today... you will like gearing down the ZX-10R I believe. 100 mph in first gear is just too tall (I think anyways).
outer bolt is for speedometer I believe and you should not put a wrench to it or may distort readings if you mess it up; can't prove but why take chances? just trying to help you.
Have fun stay alive.
posted June 14, 2004 04:05 PM
Buy a set of Harbor Freight deep impact sockets. A whole set costs about as much as one socket from the auto parts store. Then you'll have them all.
salsa1
posted June 15, 2004 04:43 AM
Edited By: salsa1 on 15 Jun 2004 08:01
600rr:
like I promised; deep socket size is 1- 1/16 inch ;not metric (I realize) but it worked just fine. "Advance Auto parts" store I purchased from did not have metric that would fit and again no problem using 1-1/16 standard.
priced whole set of sockets at K-Mart and price was above $30.00 ;single deep socket at auto parts store was less than $6.00. (I got plenty of other sockets already).
actually any mechanic will probably have and ya should not have to buy. I did cause I initially tried to take off by myself before getting someone with an air impact tool.
Hoses around cover are a bit bothersome to fit sprocket cover but nothing major also be careful about two small bolt sleave spacers falling out from sprocket cover. I needed to use mechanics magnet stick to retrieve while doing job.
there ya go; let me know if I can help.....
note:
I am happy with 16 tooth front but will put on 15 to see if more fun for every day driving and 1/4 mile runs ;yet to see how my ZX-10R launches hard after lowering and strapping front down.
Right now it's very difficult (with stock height) to manage front tire down during top of first gear . I must have a ringer hehe.
Have fun ;stay alive.
