BIKELAND > FORUMS > ZX10R ZONE.com > Thread: tether aka killswitch dragracing? NEW TOPIC NEW POLL POST REPLY
floyd
posted June 09, 2004 05:37 PM        Edited By: floyd on 9 Jun 2004 18:43
tether aka killswitch for dragracing?
Just got my tether to hook up on my 10 and need to knwo what wire to splice it into.Anyone that has already hooked theirs up?
johnnyboy
posted June 09, 2004 05:41 PM
Speak English... Are you saying kill switch?
floyd
posted June 09, 2004 05:42 PM
yeah kill switch
johnnyboy
posted June 09, 2004 05:53 PM
Drill a 1/16 hole in the top half of the kill switch, insert your I-bolt and rap the tether one half turn, clockwise around the handle bar. You will se mechanically how it works.
Peace,
Johnny boy!!!!
BROOKLYNNYZX12
posted June 09, 2004 05:57 PM
Crotch Rocket gave me a great tip,go to a locksmith or a hardware store,get the flexible keychains that look like a telephone cord..(coil type)drill a small hole in the on/off switch..#6 sheet metal screw attach the keychain to the switch,the other end to your jacket....about 5 bucks
Orient Express Top Street Bike Winner 8-4-07
posted June 09, 2004 06:17 PM
Only problem is some race santioning bodies do not allow the "ghetto tether" modification.
A good one like MPS, Pingel, etc starts at $40 and offers some kind of contingency.
floyd
posted June 10, 2004 05:24 AM
I have the kill switch from Schnitz I am not about to cheap out on a $10,000+ bike and put a screw in the factory switch.
Just wanted to know if someone who already installed one could tell me which wire to splice into.
posted June 10, 2004 06:26 AM
Take the control cluster off the handlebar and there are two wires coming from the kill switch. Either of those will work.
magikmike
posted June 10, 2004 05:04 PM
There are two wires from the factory kill switch you can tap into, they are Yellow/Red and Red.
You can either cut them and wire the new teather into it, and disable the factory one. Or splice in and then both will work and you can take your teather out when you are not at the track. If you do it this way, just note that both kills will need to be triggered to work. Meaning, plug the teather in, flip the factory one to kill, then when you pull the teather out it will kill properly. Thats the way I did mine.
floyd
posted June 11, 2004 04:37 AM
Exactly what I was looking for Mike thank you
posted June 11, 2004 06:31 AM
Good info Mike!
floyd
posted June 18, 2004 07:13 AM
Mike,
Thanx again
I just installed the tether, adjustable rear lowering links,and brackets for front end lowering strap tommorrow morning I am going to lower the forks thru the triple round an inch or so also going to reverse the shift pattern then hopefully tommorrow night take the 10 for its first dragstrip run
0.30951690673828 seconds processing time
