BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Freaking Governor NEW TOPIC NEW POLL POST REPLY
drowland
posted June 01, 2004 05:58 PM
Freaking Governor
Yes guys the ZX10R has a governor in 6th gear. You can actually go faster in 5th. Just had my 10R dyno tuned today for the new Ti Force and PC3 at a authorized tuning center. Well Guys lets find a way to bypass it!!!!!!!!!
Warlord
posted June 01, 2004 06:01 PM
What were the dyno results?
nelson10r
posted June 01, 2004 06:36 PM
Hey Drowland,
Seems to me it would not be too hard to electronicly fool the computer into thinking it is in 5th while in 6th... Me and my ohm meter will look into this and let ya know. Is there a switch that tells the computer what gear the 10R is in???
Nelson10R
Why put off till tomorrow a wheelie you can do today...
drowland
posted June 01, 2004 06:51 PM
Im sure there is a way sort of like the TRe mod I had on my GSXR1000 and muzzy black box on my 12. I sure hope so body comes up with it. Cause after I get some head work down and a 40 shot of NoS going to hit the Maxton Mile and redem myself in the 200mph club!
kz2zx
Nobody in Particular
posted June 01, 2004 06:56 PM
The online 'fiche lists this:
13151 13151-0005 SWITCH-COMP,NEUTRAL
I don't know what the manual has to say about it, mine's still on order
drowland
posted June 01, 2004 07:05 PM
Warlord, The results were a bit dissappointing when I saw the numbers. Then I asked chuck who is the owner of RC's Performance
Laurinburg NC 28352 ( Dyojet Authorized tuning center ) what the hell? He said his dynojet always show low about 10 hp low. I was up 11 hp from stock and the torque and throttle response is totally changed this bike. The corrected Hp with pipe was I think 157 hp. He said that is actually more than all of the other bikes that has the similar mods on. Pipe and Powercommander. ie. Busa, GSX1000R, ZX12R. And I have personally owned all of these bikes with all the similar mods. And I will tell you The ZX10R with The Ti force and PC3 is the fastest of all of them. Well till hits the fucking governor. LOL I will have it dynoed on a dyno that I am familar with soon. The throttle response is way better than stock now and its a wild ride. Puts the rest of these bikes to shame.
cjzx-10r
posted June 01, 2004 07:47 PM
I wonder if that high dollar ecu from kaw is restricted? Do anybody know?
DB
posted June 01, 2004 08:10 PM
If the 10r has a govenor then why hasn't it been mentioned before today? Theres been alot of dynoed 10r's, why hasn't anyone said this before?
Dan
04 ZX10r (Track only)
08 Concours14
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted June 01, 2004 08:20 PM
There is a gear position sensor. The values for each gear are in the shop manual.
worm~hole
posted June 01, 2004 08:21 PM
...why not indeedy?
who would do us harm.”
-George Orwell
12RPilot
posted June 01, 2004 08:43 PM
...and what speed is it restricted to?
NESBA #209
bluedevil
posted June 01, 2004 09:08 PM
I would guess it is restricted like the Busa and 12 at 186mph. Two motorcycle mags ran to exactly 186mph on their tests, that's when I began to wonder also that it must be restricted. This is just a quess but with the HP,power/weight,and the sleeker frontal area of the 10 it sure seems like there something going on.
DB
posted June 01, 2004 09:14 PM
where is extremelean when you need him??
Dan
08 Concours14
tuusinii
posted June 01, 2004 11:49 PM
Of course there is a covernor, but the bike can't go much faster also because the gearing (if stock) runs out on 6th.
drowland
posted June 02, 2004 04:34 AM
Well guys in in fifth showed over 190 and then in fifth was lower. Chuck said it was like 176 but the speedo said 188
supraman95mb
posted June 02, 2004 06:19 AM        Edited By: supraman95mb on 2 Jun 2004 07:20
So is it possible that the 10R reads gearing and provides a map for the gears like the GSXR 1000's do? If so maybe we can get someone to make us a TRE to wake this bad boy up in the midrange. I know stock the GSXR retards timing in the lower gears to keep the bike planted. With the TRE it runs better timing and makes gobs more power.
02 Stroked 12R
95 Supra Single Turbo 750+ hp
12RPilot
posted June 02, 2004 06:36 AM
I know the ECU on our 10s reads the gear selection, but so did my 2000 ZX-12, and they weren't restricted. Now I gotta wonder what's inside the off-road ECU that Kawi offers for the 10.
NESBA #209
posted June 02, 2004 06:45 AM
IT HAS A GEAR POSITION SENSOR. THE RESISTANCE VALUES IT SENDS TO THE ECU ARE LISTED, FOR EACH FUCKING GEAR, IN THE SHOP MANUAL.
drowland
posted June 02, 2004 06:53 AM
Well how can we fix the problem Bovinespongiformencephalo??????????
MAVRIK
posted June 02, 2004 07:31 AM
Most likely then, then first couple of gears might also have timing retardation.....we have to find out gentlemen and ladies....
Everyday is holiday, every meal is a feast....
drowland
posted June 02, 2004 11:12 AM
Well the latest is real mph is 183mph at Maxton MIle oustside laurinburg this past weekend. Then the fucking governor kicks in. However there are some guys working on it!
12RPilot
posted June 02, 2004 01:16 PM
No shit!! Just like I said a long time ago when we were mulling over a digital gear position display. Now how about yelling a solution to the problem. Sheesh!!
NESBA #209
worm~hole
posted June 02, 2004 01:20 PM
...aaaarrrrrrgggggghhhhhh.....my 'ears'!!!!
-George Orwell
nelson10r
posted June 02, 2004 05:08 PM
I may breadboard up a circuit that will light up a digital L.E.D to tell what gear the bike is in... if the bike IS limited in 6th that would be easy to fool just put an in line resistor on to match the resistance that is input into the cpu while in 5th gear...could even be on a swtich.
Nelson10R
posted June 02, 2004 05:17 PM
EACH GE... Sorry. Each gear outputs two resistance values. Whether both are communicated to the computer is a question for the smart guys. Either way, it's a 50¢ experiment to see if a TRE style 5th gear shunt will add top speed or torque in the lower gears. I assumed that was obvious since switched gps shunts are a way of life for gixxer owners.
0.42522692680359 seconds processing time
