posted June 06, 2004 04:33 PM
Good weekend for mods Fitted an Ohlins rear shock,micron high mount and did a fender eliminator this weekend,now to go ride.
posted June 06, 2004 06:49 PM
I'm sitting here, trying to get up the gumption to attach my speedohealer. It's got the factory harness connectors, so not too much of a hassle.
posted June 06, 2004 08:06 PM
I built my own plug and play Yellow box harness out of spares. Be careful about clearance issues around the speed sensor connection. You want to get the connectors far enough forward to clear the fairing. It's tight down there.
posted June 06, 2004 08:12 PM
Yep. Took the bracket loose and routed the cable through it alongside the factory wiring. Also zip tied the connector to eliminate any flexing and possible stress on the wires. Taped it up to give it some moisture protection.
