BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Ping: engineermike NEW TOPIC NEW POLL POST REPLY
Broken Wind
posted May 13, 2004 05:38 AM
Ping: engineermike
Are you making any passes this week? You ready to get some nines? If so post the results of three of your passes, launch rpm, 60' 330' 1/8th and trap speed.....let us analyze
chitty chitty bang bang
salsa1
posted May 13, 2004 09:30 AM
Hi mike and Broken Wind pick what you think you need from this post if you like......It's real as far as I know. Just trying to help; a ZX-10R ought to get into the nines if a guy really wants to ; I think .
Read and think about it.
Peace.
normjack
A little Knowledge is Dangerous
Posted: Mon May 03, 2004 8:52 am Post subject: 04 ZX10 1/4 times
I ran my ZX10 this past weekend in AMA Postar 1000SS
After Lowering it, gearing it. Akrapovic EV 1 pipe, PC3USB tuned MR9 fuel. Stock Wheelbase.
I ran 9.46@150
1.63 60ft
4.16 330
6.20@121 1/8
7.95 1000ft
9.46@150mph
after only 7 passes. I'll be going 9.20's after some seat time and practice.
_________________
04 ZX10 Bone Stock (Blue)
02 ZX12R Hindle Step pipe, Muzzy Adv 2.5deg, 93 otc gas, no filters. 2" Ground Clearance, 16/44 gear, 9.42@151.53mph stock Wheelbase
9.24@150mph 60" wheelbase Stock Motor
8.83@163mph 60" wheelbase on NOS
salsa1
posted May 14, 2004 05:12 AM        Edited By: salsa1 on 14 May 2004 06:38
Hi Mike and company; more (engineering) data from same source I plagiarized first post above:
Notice Mr Normjack went from 151 hp to 165 hp. Significant wouldn't ya think...:
I guesstimate you would pick up at least 4hp with just modded can (as per Mr. DKET) and at least 4 hp more with MR9 fuel (as per Muzzy dyno charts with MR9). This for about $50.00 or less? (depending on MR9 fuel price).
Seems in line with your goal to spend as little as possible. Just pointing out options for ya to choose from.
Peace and Freedom.
normjack
Posted: Wed May 12, 2004 8:20 am Post subject:
Mines Dynoed 151 Bone Stock 400 Miles
157 with Akra Pipe
165 with Akra pipe, PC3Usb tuned and VP Ultimate 4 fuel
I'm gonna try it with MR9 Fuel next
_________________
Broken Wind
posted May 14, 2004 10:49 AM
soooooo it's not the bike after all......mike are you listening?
engineermike
posted May 16, 2004 12:00 AM
I'm here!
I haven't run since trying the 15 tooth front and slowing down.
My best pass to-date is:
60': 1.78
330': 4.48
1/8: 6.62 @ 115.1
1/4: 10.06 @ 144.9
This is lowered 4" rear, strapped front, 16 tooth front sprocket, 185 lb rider.
Best 60' to-date: 1.690 (15 tooth front sprocket)
Best 330' to-date: 4.445
The problem is that with more throttle and aggresive clutch release, comes more wheelies.
This d@mn bike wheelies uncontrollably in 1st and the beginning of 2nd gear at the stock ride height, which makes the 9.70 bone stock claims seem unbelievable.
Ryan Schnitz recommends adding weight to the front axle and removing the seat (lower CG).
I would like to know the WHOLE set-up of someone running mid/low 9's with a ZX-10R.
Mike
'04 Orange 10R
0.24197316169739 seconds processing time
