bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted May 11, 2004 10:35 PM
Speed sensor connector
is identical to the white connector used on the R1 speed sensor and the Gixxer GPS (where the TRE goes). Yellow Box speedo correctors can easily be set up for plug and play if you hate hacking into the wiring for that kinda stuff. Also, it should be a good speed sensor tap for the DIGI and Acumen GPI units. Has anyone done one of those yet?
posted May 12, 2004 01:28 AM
I have a yellow box but havent had the need to hook it up yet.
CanyonCarver
posted May 14, 2004 05:33 AM
FWIW, I have a Speedo-Healer on order from Cal-Sportbike. It is the new version 2.0 and will have plug & play capability with the proper connectors and no need to splice or tap any wires.
v2.0 also has the ability to do top-speed recall, convert kmh to mph and vice-versa and they have an online calculator at their website that helps you figure out the correction factor for gear changes, etc.
I think it runs $89.95 from Cal-Sportbike.
