BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Need Chain Sprocket Input NEW TOPIC NEW POLL POST REPLY
runninhorn
posted May 07, 2004 08:32 AM
Just want to put an aftermarket chain and rear sprocket on my 10, just wondering which chains and sprockets you recommended? If I want to go "up" in the back, would it be best to go 2 or 3 teeth? Any info appreciated, thanks......
  Ignore this member    Click here to send runninhorn an AIM message.
MAYHEM
posted May 08, 2004 03:59 AM
if you are going with a 520 conversion i recomend the EK X ring chains because of the high tensile strength 8400, and on the sprockets i go with the AFAM on the front because they come with the extra lights holes drilled in them, and the Spocket Specialist on the back because of the wide variety of options they offer for them. i am currently running a 16/41 gear combo.
1143nos
posted May 08, 2004 05:20 AM
where can I order those sprockets in 530 form?
  Ignore this member    Click here to send 1143NOS an AIM message.
posted May 08, 2004 05:23 AM
EKs would always stretch on me on my 1270. Course, that was 190hp. Prolly won't be an issue on a 160hp machine with considerably less torque. I have always had my best results with the DID chain.
Big Daddy
posted May 08, 2004 07:31 AM
Both the high end EK & DID 520 chains are capable of lasting many miles with proper maintenance, however i'm not inclined to convert over to a 520 just yet so i just replaced the OEM cs with -1 AFAM. The sprocket availability for the 10r are somewhat scarace right now as they are DIRECT replacements sprockets from the 98-02 zx6r (rear) & 96-99 zx750r/rr (front).
BD
1143nos
posted May 08, 2004 05:50 PM
thanks.
runninhorn
posted May 08, 2004 06:21 PM
BD
know any place I can call on Monday to order both the 520 chain and rear sprocket that would have it in stock for the 10R? I called AFAM, but they dont seem to want any business......or didnt want to take my $$$.......oh well, ill find someone that does........
Big Daddy
posted May 09, 2004 12:25 AM
Sorry i don't.....the 520 chain can be had from just about anyplace but the sprockets are another story.
BD
runninhorn
posted May 09, 2004 08:42 AM
BD
ive heard the 10r is using the same 525 sprockets as the following models.
98-02 zx6r for the rear
96-99 zx7r/rr for the CS
big daddy
posted May 09, 2004 10:53 AM
Yes they are..........well where ever did you find such info? :-)
dnwhoop02
posted May 10, 2004 11:23 AM
hahaha... that was a good one!
David
'04 ZX-10R
'00 SV650
  Ignore this member    Click here to send dnwhoop02 an AIM message.
runninhorn
posted May 10, 2004 11:46 AM
LOL, a little birdy told me
roym3
posted May 11, 2004 10:10 AM
Talk to Carol at Sprocket Specialists.They have Front and rear.I think they have all sizes also.800 782 8200.
runninhorn
posted May 20, 2004 11:47 AM
my sprocket just arrived, and on the package it says----
"GSX-R 600 97-00/750 98-00"
PITCH 525
Part Number- 28401
Is this the correct sprocket? Just making sure before I try to install it.........
big daddy
posted May 20, 2004 12:44 PM
PITCH 525
Part Number- 28401
Yes that is the correct AFAM part# for the GSXR's /Sv650 / 96-99 zx-750rr/r and a couple of others so no problem with install.
BD
ice 1
posted May 20, 2004 01:01 PM
We have been endurance racing for the last several years, and haven't found a chain better than the DID X-Ring. The DID X-Ring chains have outlasted the best Tsubaki, Regina, and RK chains by a good margin on our bikes. FYI we run only 520's.
The Sprocket Specialists Titan Tough stuff has performed well for us. Don't get the non-hard anodized sprockets. AFAM also makes excellent sprockets. You won't go wrong with either one.
0.25401592254639 seconds processing time
