BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Seat Cowl fix NEW TOPIC NEW POLL POST REPLY
zx10Roger
posted May 05, 2004 03:19 PM
Seat Cowl fix
Just wanted to let you guys know got my cowl today ,put it on it was loose.If you pry the little tongs where it latches on to bike in a little to where it's tighter on the cross bar it fits much tighter,maybe that's why Kawi has the little tongs on there.Hope this helps.
JNM
posted May 05, 2004 05:46 PM
Thanks for the tip. Mine should be in Friday, so we'll see what happens. BTW, how loose was it?
CCS #428
RichTJ99
Newbie
posted May 05, 2004 06:02 PM
Are you saying to bend the metal to the left or right?
Admin of http://www.zx-10r.net
  Ignore this member    Click here to visit RichTJ99's homepage.
12RPilot
posted May 05, 2004 06:08 PM
Up
zx10Roger
posted May 05, 2004 06:46 PM
12r actually was the first to post the fix on another thread I just saw.I put mine on and bent the little pieces to make it tighter and posted it.
krazy1
posted May 05, 2004 08:15 PM
My seat cowl came with two rubber plugs to damper the area you guys are talking about.
k1
  Ignore this member    Click here to visit krazy1's homepage.
12RPilot
posted May 06, 2004 01:38 AM
Mine came with those rubber buttons too. It still was loose on another axis (up and down direction at the back). After squeezing the fork shaped bracket at the back a tad it's much better. Now I'm keeping an eye on it to make sure it doesn't rub on the tail anywhere.
posted May 06, 2004 03:58 AM
Yep, it does seem to need a bit of tweaking.
0.24414300918579 seconds processing time
