BIKELAND > FORUMS > ZX10R ZONE.com > Thread: ZX-10 At Local 1/4 Mile, Quick Version........ NEW TOPIC NEW POLL POST REPLY
C Dolan
posted April 10, 2004 10:31 PM
..........before I hit the sack.
. Bike is geared way too tall in 1st to drag race well, with 230 rider weight.
I had to come out at 8000 to 10000 rpm and slip the clutch a ways.
When it came on the pipe, I had to roll the throttle to match and carried the front end about 6" to a a foot off the ground.
Only used 3 gears in the quarter. The shift to 4th, with my weight was a waste of time, so I was better running out 3rd gear to finish.
Best run was 10.68 @ 135 mph. after 4 passes. I didn't want to run it anymore till I try lower sprocket and look at clutch. Seems ok from "fell" and clutch cable slack didn't change.
Found out that bike will pull to 14,000 rpm, :o when I missed a shift from 1st to 2nd. When I released clutch, I found that I was still in 1st and ran it up. Didn't seem to be hitting any rev limiter.
60' : 1.86 sec.
330' : 4.74 sec.
1/8 : 7.06 @ 109 mph
Air: 71 deg. @ 59 % Humidity
Eq Altitude: 1356' above sea level. ( 10.68 would be 10.55 if adjusted like magazines do )
Michael Lee
Purchase Ivy
posted April 10, 2004 10:34 PM
Thanks for sharing. Can you compare with any other liter bikes you have taken to the strip? - Mike
Broken Wind
posted April 11, 2004 05:30 AM
wow, crossing the line in third at 135mph, was she in the red? The front sprocket is the same one that is used on the zx-7 while the rear is the same as the 12.
chitty chitty bang bang
C Dolan
posted April 11, 2004 08:17 AM
Wow, crossing the line in third at 135mph, was she in the red? The front sprocket is the same one that is used on the zx-7 while the rear is the same as the 12.
But do they have 13k redlines ?
ZX-10 will pull to 14k. ( past redline )
C Dolan
posted April 11, 2004 08:22 AM        Edited By: C Dolan on 11 Apr 2004 21:31
Same track:
2002 R-1, BST carbon fiber wheels, full Akra, airbox mod:
10.80's @ 134 mph, 4 full gears used. ( 153 hp on dyno )
2001 GSXR 1000, bone stock: 10.57 @ 137 mph, used all of 4 gears.
Bone stock '99 Hayabusa: 10.34 @ 137 mph, easier to launch.
1999 R-1, bone stock: 10.89 @ 132 mph, all of 4 gears.
Broken Wind
posted April 11, 2004 09:13 AM
doubt it, BUT if you wanna go one down in the front,order a minus one for a zx-7, or if you prefer to go up in the rear,...........
Michael Lee
Purchase Ivy
posted April 11, 2004 09:18 AM
thanks
frEEk
posted April 11, 2004 06:36 PM
oh geez, i had to laugh out loud on this one, cause dolan has prolyl taken just about EVERY bike to the track oh the unknowing irony.
zeta xray
posted April 12, 2004 10:19 AM
I read somewhere that the rev limiter comes in @13,700.
0.24406099319458 seconds processing time
