posted April 08, 2004 07:11 PM
Just completed 600mile service.
Alrighty then... I just did the 600mile service... changed the oil, lubed the chain etc etc... I double checked all of the torques in the A&P doc and all is fine...
BTW thanks for the tip about the tinfoil whoever that was.
PS... filter wrench is a must!
KZ2ZX
Nobody in Particular
posted April 08, 2004 07:15 PM
Me, I think, and you're welcome, but Chris Dolan also posted about it on LABusas. I've used the trick for years, but he may have (probably did) had it first.
I've not had to change anything on mine but the oil. Wipe it down with WipeClean, and that's about it... chain lube, like you noted, and a rear brake pedal adjustment.
But mine is getting buzzier, I've noticed, and the transmission smoother.
posted April 08, 2004 07:19 PM
same fer me... just went through the A&P sheet and the toque specs.. pretty basic but worth a once over.
posted April 08, 2004 07:37 PM
Fish.. if you had a Hayabusa.... you would have that trick down pat....lol
RichTJ99
Newbie
posted April 09, 2004 08:20 AM
A&P sheet?
Can ya scan a copy of that? I would rather do my own 200 dollar "600 mile" oil change.
Admin of http://www.zx-10r.net
posted April 09, 2004 08:56 AM
sorry fellas... info can be found in the owners manual.. just ask your dealer for a copy of the torque spec sheet.
hammerli
posted April 09, 2004 10:27 AM
Since I am sure a lot of people would like access to the sheet, if anybody has a scanned copy, send it to me and I'll host it and put the link in a thread.
badboy
posted April 10, 2004 03:18 AM
What a dork
posted April 10, 2004 05:25 AM
Edited By: fish_antlers on 10 Apr 2004 06:46
is there a prob there badboy? Ever think that there are some documents I CANT give out?
posted April 10, 2004 05:33 AM
Edited By: fish_antlers on 10 Apr 2004 06:35
Hey badboy.. this is the best that I am permitted to do... dont be an asshole.
quote: The torque values listed are for assembly and preparation items only, see the appropriate Service
Manual for a more comprehensive list. Check tightness of all fasteners that are in the table before
retail delivery. Also check to see that each cotter pin or circlip is in place.
Torque
No. Fastener
N·m kgf·m ft·lb
Remarks
Frame/Steering
1 Handlebar bolts 25 2.5 18
2 Steering stem head nut 78 8.0 58
Brake
3 Front master cylinder clamp bolts 8.8 0.90 78 in·lb S
4 Front caliper mounting bolts 34 3.5 25
5 Front brake bleed valve 7.8 0.80 69 in·lb
6 Rear master cylinder mounting bolts 25 2.5 18
7 Rear caliper mounting bolts 25 2.5 18
8 Rear brake bleed valve 7.8 0.80 69 in·lb
Wheel
9 Front axle nut 108 11.0 81
10 Front axle clamp bolts 20 2.0 14.5 AL
Torque
No. Fastener
N·m kgf·m ft·lb
Remarks
Suspension
11 Front fork clamp bolts (Upper) 20 2.0 14.5
12 Front fork clamp bolts (Lower) 30 3.1 22 AL
13 Rear shock absorber mounting nut (Upper) 34 3.5 25
14 Swingarm pivot shaft nut 108 11.0 81
15 Swingarm pivot adjusting collar locknut 98 10.0 72
Others
16 Front footpeg stay bolts 25 2.5 18
17 Rear footpeg stay bolts 25 2.5 18
Engine
18 Engine oil drain plug 20 2.0 14.5
Cotter pin or Circlip
19 Rear axle nut cotter pin - - -
20 Rear master cylinder cotter pin - - -
21 Front footpeg pin circlip - - -
22 Rear footpeg pin circlip - - -
AL: Tighten the two clamp bolts alternately two times to ensure even tightening torque.
S: Tighten the upper clamp bolt first, and then the lower clamp bolt.
Standard Torque Table
This table relating tightening torque to thread
diameter, lists the basic torque for bolts and
nuts. Use this table for only the bolts and nuts
which do not require a specific torque value.
All of the values are for use with dry solvent
-cleaned threads.
General Fasteners:
Threads Torque
dia. mm N·m kgf·m ft·lb
5 3.4 ~ 4.9 0.35 ~ 0.50 30 ~ 43 in·lb
6 5.9 ~ 7.8 0.60 ~ 0.80 52 ~ 69 in·lb
8 14 ~ 19 1.4 ~ 1.9 10.0 ~ 13.5
10 25 ~ 34 2.6 ~ 3.5 19.0 ~ 25
12 44 ~ 61 4.5 ~ 6.2 33 ~ 45
14 73 ~ 98 7.4 ~ 10.0 54 ~ 72
16 115 ~ 155 11.5 ~ 16.0 83 ~ 115
18 165 ~ 225 17.0 ~ 23.0 125 ~ 165
20 225 ~ 325 23.0 ~ 33.0 165 ~ 240
kz2zx
posted April 10, 2004 07:01 AM
quote: badboy opined:
"sorry fellas... info can be found in the owners manual.. just ask your dealer for a copy of the torque spec sheet."
What a dork
And I say: See over under the guy's name and avatar - yeah, the one you insulted - where it says "Administrator"?
As in, he may be liable for stuff posted up, especially if he posts it and not one of us?
hammerli
posted April 10, 2004 07:15 AM
Fish, thanks for posting those numbers. I live in a small town and the nearest dealer has a service department run by idiots. They won't give me any kind of information since I don't have any work done there. Actually a few years ago I did have them mount a new front tire before a trip to CO (from MI). After getting the bike off the trailer in CO, I discovered the morons had mounted the tire backwards, needless to say I have not been back to their service dep't.
TAFB
posted April 10, 2004 07:28 AM
thanks fish! like hammer, i have not found anyone i trust to work on my bike...at a minimum, i'd like to be able to double check what they were supposed to do.
D
posted April 10, 2004 08:22 AM
Thanks for the specs.
1bad7
posted April 10, 2004 11:56 AM
Thanks fish as always. I just have 1 stupid question...what is with the tinfoil?
badboy
posted April 10, 2004 01:12 PM
I am sorry ...
kz2zx
posted April 10, 2004 01:25 PM
Edited By: kz2zx on 10 Apr 2004 14:26
quote: Thanks fish as always. I just have 1 stupid question...what is with the tinfoil?
You work it over the headers, under the oil heat exchanger, and behind the oil filter, to make sort of a waterslide-shaped funnel for the oil from the filter to run down and drip into your oil change pan.
I take a sheet of tinfoil, and fold it in thirds width wise to reinforce it - I have a strip about 4" wide and a foot or more long. I then feed it under the heat exchanger, ofer the headers, and behind the oil filter housing.
One cap wrench and a 10" extension later, I unscrew the filter, and tip it up on the threaded post it mounts on so it can run down the tinfoil slide and into the pan. Then I take the filter out between the headers wtih my left hand - no drips, no mess.
Pull the tinfoil down while it's over the pan, and you're done.
1bad7
posted April 10, 2004 03:18 PM
That's AWESOME!!! See that's exactly why I come here, for all the good info. when I get mine(whenever that may be cause my fucking dealer sucks ass) I will most definitely do that. Thanks guys.
posted April 10, 2004 04:00 PM
Edited By: fish_antlers on 10 Apr 2004 17:01
note that the colums didnt transpose very well.. there are 3 figures, and in order for each troque spec they are :
N·m, kgf·m, ft·lb
ie:
=25 n-m
=2.5 kgf-m
=18 ft-lb
NOTE some are in inch-pounds and do say sao... also there is a side bar.... where these letters appear do what they instruct:
If someone has more time on their hands they could make that post of mine line up all nice and pretty so it made more sense.
kz2zx
posted April 10, 2004 04:02 PM
Fish, send it to me, I'll put in a spreadsheet and take a snap of it, post it up...
posted April 10, 2004 06:42 PM
uh.. .I cant do that. you guys will have to work with what I gave you (above...) I'm NOT ALLOWED to give out the document, or I would.
