BIKELAND > FORUMS > ZX10R ZONE.com > Thread: relasing clutch NEW TOPIC NEW POLL POST REPLY
a
posted March 31, 2004 07:26 AM
relasing clutch
When downshifting and relasing clutch quick as in instant there is big clunk from engine as is too direct or something. If relasing normal its ok, only if i drop clutch and only on downshifts. Is there anyone else expirience this prob or is that just back torque limiter or what. Mind you that im still in break in period so i downshift at lower rpm below 4000. Im usin clutch very little as i upshift without clutch or very little clutch. Is maybe that clutch is not break in and i should use it more. I have only 100miles on it.
posted March 31, 2004 10:16 AM
Prolly something to do with the slipper clutch.
posted March 31, 2004 07:58 PM
me too at this point... but I only have about the same mileage..... enige really needs to be broken in..... give it a chance to wear in and use all the gears...
trikchop
posted March 31, 2004 10:37 PM
after you get up in the miles itll quit unless you just dump the clutch. also on brek in on mine it would sometimes not go all the way into gear until i let the clutch out. but now it werks like dream
0.24224305152893 seconds processing time
