BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Lights NEW TOPIC NEW POLL POST REPLY
D
posted March 30, 2004 07:41 AM
Lights
So what bulbs does this thing use?
And has anyone figured out how ta make both lights come on on both beams yet?
12RPilot
posted March 30, 2004 08:57 AM
If they ever get the damn shop manuals distributed, I'll figure out the headlight thing. I'm also wondering if I can build a digital gear position indicator like I did for the 12. Need that manual, dammit!!!
NESBA #209
frEEk
posted March 30, 2004 09:15 AM
interesting, i was gonna say H4 but it uses H7.
http://buykawasaki.com/scripts/EmpartISAPI.dll?MF&CAT=KMC&APP=KMC&session=GwTsRc1aYcGHpcKgkgmv70%2A%2A&title=ZX1000%2DC1&mode=1&model=ZX1000%2DC1%2D2004&speccode=US
D
posted March 30, 2004 10:36 AM
So both lights are already dual beam bulbs according to parts diagram.
So what needs ta happen for dual low beam and high beam use?
As long a s a relay is used then it shouldn't be a biggie to make the other light work - right?
zeta xray
posted March 30, 2004 11:04 AM
It uses 2 - H7 bulbs. H7's are single filament bulbs. No separate Hi and Lo beam. The Kawasaki parts diagram shows three blades on the bulb, which would tend to indicate there are 2 filaments. They actually only have 2 blades on the bulbs.
D
posted March 30, 2004 12:03 PM
Is there a dual filament bulb that fits (and will reflect correctly)?
zeta xray
posted March 30, 2004 04:52 PM
H7 is a smaller base than the H4 bulbs which are dual filament. I have looked through several sources but I have found no dual element bulbs that fit the H7 hole.
iculukn
posted March 31, 2004 09:27 PM
Someone figure this out and let us all know how,
-lukn
A "99.99% open mind", is still closed!
0.21645402908325 seconds processing time
