BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Oil filter? NEW TOPIC NEW POLL POST REPLY
edgar ayoroa
posted March 25, 2004 06:37 AM
Oil filter?
What can be used to get oil filter off ZX-10R; is new tool required?
Thanks!
Latin Shuffle
ninja_12r2000
posted March 25, 2004 06:40 AM
Oil filter
Did you got a picture ???
Is that so much hard to get off ???
Don't tell me that we have to remove the headers pipe ???
marco383
posted March 25, 2004 07:12 AM
Good timing: I replaced mine about a half hour ago. A small, adjustable oil filter wrench (Auto Zone, Pep Boys, etc.) does the trick. Watch out for the header pipes, which will be hot if you're doing the job correctly.
posted March 25, 2004 07:31 AM
Good tip!
edgar ayoroa
posted March 25, 2004 09:12 AM
Thanks;went to advance auto parts store last night but they were closed before I got there; was wondering if they would have something for such a small oil filter. Hard to get a good grip on filter cause it is stuck between header pipes
Ninja 12_R2000:
Header pipes do not need to be removed;just be ready to have oil over them as location of filter is above headers. Wipe off best you can and let excess burn while you check for leaks worked for me. Might be way to use oil solvent of some kind to clean mess. Open for suggestions.
Hope this helps.
Latin shuffle
Latin Shuffle
blackzx1kr
posted March 25, 2004 09:57 AM
Lay down tin foil over them so the oil runs down!
Roy
Zed
posted March 25, 2004 10:31 AM
What mileage are you guys changing the oil at?
Live long, and Faster
KZ2ZX
Nobody in Particular
posted March 25, 2004 11:22 AM
I did mine at 200 for the first one - shoulda been 100 miles, but, hey, I had to go to work. The manual says 600 miles for the first, then every 7.5k after.
Putting tinfoil over the headers didn't really help - the watercooler for the oil got in the way of a nice job, and I ended up with oil on the collector and on the watercooler.
To answer the first question, get a $1.99 oil filter cap - it's driven with a 3/8 ratchet, and I used a 9" extension.
I had to take the lowers off to do this, and you need a 4mm allen wrench for that. The drain plug is 17mm.
Have fun
ASMA 47
WERA 147
www.dhowellbooks.com
Zed
posted March 25, 2004 02:29 PM
Thanks. Now all I need is the bike. If this goes on much longer, I'll need an oil change!
0.253338098526 seconds processing time
