BIKELAND > FORUMS > ZX10R ZONE.com > Thread: ZX-10r Dry Nitrous Kit results... NEW TOPIC NEW POLL POST REPLY
pooh
posted March 20, 2004 01:43 PM
This is a plug and plug controller. No Power Commander needed, choose what throttle position and what gear you want it to start spraying, all OEM connectors. No fuel system upgrade needed. If you have a Power Commander then this system keeps your custom map until the gas start spraying then it uses the stock fuel system to add the necessary fuel.
This is the same Dry Nitrous controller as used on the busa.
0.23136401176453 seconds processing time
